Question about 92-95 civic auto to manual swap (tranny mount related)
Old Nov 29, 2006 | 01:07 PM
RACEPAK's Avatar
Default Question about 92-95 civic auto to manual swap (tranny mount related)
hello everyone.
what transmission mount will i need that will fit perfect to this swap? (aftermarket or oem (and from which car?))
somone told me that some mounts cause the tranny go lower then stock.... is it true?
thanks.
Old Nov 29, 2006 | 01:13 PM
hondamark35's Avatar
Default Re: Question about 92-95 civic auto to manual swap (RACEPAK)
... my bet is going to be on a 92-95 civic mount, both halves. the frames are the same in the manual and auto so if you have the mount for the manual trans (new oe, used, or aftermarket such as hasport) then the drivetrain will sit right
Old Nov 29, 2006 | 02:00 PM
MF Doom's Avatar
trapped in my own room!
WOW YOUR CLOSE TO CAMP1320.COM THEY ARE IN THE VALLEY
THYE ARE MAJOR STOCKING DISTUBTOR FOR INNOVATIVE MOUNTS
its the innovative auto to maunel mounts
GO OVER THERE AND YOU CAN SEE THE SELECTION OF MOUNTS AND THEY ARE VERY KNOWLEDGEABLE
Camp1320 motorsports
9843 mason avre
chatsworth ca 91311
818-718-9352
http://www.camp1320.com
Old Nov 29, 2006 | 02:18 PM
DestructoEH's Avatar
The automatic frame bracket angles upward where the manual is straight off the frame rail. I got an Innovative Mounts auto-manual conversion mount with a 60A bushing through passwordjdm.com for about $130. Hasport's auto-manual mount was a lot more expensive, but it's made of billet aluminum where the Innovative mount is made of steel. I don't know of any stock mount that would work unless you cut off the frame bracket and re-weld it in a straight position.
Hope this helps.
Old Nov 29, 2006 | 03:56 PM
egmatt93's Avatar
Default Re: (DestructoEH)
^^^link to where u got this tranny mount mines ghetto as **** atm pieces of aluminum to fit the space ftw!!
Old Nov 30, 2006 | 04:59 PM
[Ennis_D]'s Avatar
Default Re: (egmatt89)
Order the Innovative AT-MT Mount from this link...I ordered it for my buddy and I believe they got me out for about $89.95 shipped! Cheaper than ordering it from password or anywhere else that sells it for $130...
https://honda-tech.com/zerothread?id=1600661
jEGbittner
Oct 18, 2010 08:19 AM
kd97accord
Apr 29, 2010 05:06 PM
Yonick90
12
Feb 5, 2010 06:26 AM
Dbach
Feb 3, 2009 11:48 AM
Surewin
Nov 29, 2005 10:26 PM
