OK I've seached... please help on valvetrain choice for daily driven gsr
Old Nov 29, 2006 | 12:09 PM
2001B18C1GS-R's Avatar
Default OK I've seached... please help on valvetrain choice for daily driven gsr
OK well im building my 01 gsr
using endyn rollerwaves 4.2cc pistons .5mm over so 81.50 mm
balanced,blueprinted,micropolished and knifeedged block
eagle rods
arp headstuds
deck .005 head milled .005
oem head gasket
skunk2 stage 2 cams
and which valvetrain
think supertehc flat nirtide valves maybe or maybe not
about 11.4-11.6 compression depending on valves
Now i need a daily drivable valvetrain i've read and heard tit retainer wear fast and need replacing im looking for something that can handle 9200-9400 ropms daily and last a very long honda years
1. Tit reatiners =wear and tear need replacing every 6 month or 1yr or 3 years whatever.
2. I heard crower cromoly retainers using crower spring to match i heard from some builder they stay that i'm prone to float a vlave due to crower have such hard springs
3. my tuner says reuse the skunk2 spring i have already and my oem reatiner but up till 9400 rpms i'm not sure im worried about that
PLease any info comment remarks anything would help thanks alot guys
Old Nov 29, 2006 | 01:14 PM
Default Re: OK I've seached... please help on valvetrain choice for daily driven gsr (2001B18C1GS-R)
anyone with any info
Old Nov 29, 2006 | 01:23 PM
ek_kid's Avatar
one of my friends had stock retainers and upgraded cams and valve springs and the retainer snapped in half and destroyed his entire engine at 9300rpms. now i am not saying this is normal but it scares me.
Old Nov 29, 2006 | 01:36 PM
i dont know what my tuner was thinking when he said that all he said was if you get tit retainers your gonna be replacing them every 6 months or ever year so that worried be you know it not like changeing you oil it a pain in the ***
thats why im hinking of this crower choromoly but there might be someone one the site that has some great info and aint sharing but tit retainers
how are the rocket motorsports do those hold up for a while
I mean i but about 20-25,00 miles a year maybe a little less but it a lot of 9500 trips everyday al least
Old Nov 29, 2006 | 02:08 PM
ek_kid's Avatar
Default Re: (2001B18C1GS-R)
I have never herd of titanium retainers going bad after 30,000 mi. But i am sure your tuner knows more than me well i hope someone helps you out. good luck
Old Nov 29, 2006 | 03:56 PM
thanks yea my tuner says tit sucks and dont recommend it for daily driven cars i mean he know that i drive around alot and put alot of miles on my car while beating the shitof it vtec is like crack im addict and i cant stop
Old Nov 30, 2006 | 05:51 PM
anyone running this retainers and how many miles on them how are they what springs are you running with them and also how many miles and have they wore down yet thanks
Old Nov 30, 2006 | 06:10 PM
jvtec95's Avatar
Old Nov 30, 2006 | 06:44 PM
UncleD's Avatar
Default Re: (jvtec95)
Rm SL's > ANYTHING else thats out there.
Old Nov 30, 2006 | 09:37 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2001B18C1GS-R &raquo;</TD></TR><TR><TD CLASS="quote">thanks yea my tuner says tit sucks </TD></TR></TABLE>
Are you sure your tuner doesnt suck tit?
Old Dec 1, 2006 | 01:51 AM
haaaha good one i suck at typing but my tunere staes that titanuim reatiners sucks tit due to the wear they do and due to how thin athen they crack then you blow you motor then your cry i know i know its a horrible story but **** happens then you die right right
Old Dec 1, 2006 | 02:18 AM
permaisuri's Avatar
Default Re: (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">
Are you sure your tuner doesnt suck tit?</TD></TR></TABLE>
LOL!!!!!!!!!!!!!!!!!!!
Old Dec 1, 2006 | 06:13 AM
Player5530's Avatar
im runnng supertech complete valvetrain im my R and it works great i miss shifted twice going from 3rd to 2nd and i dont know where the rpms went too the needle went pass 9k and my motor didnt blow up. this is running toda B cams. i just recently took the motor part and i inspected the valve train and everthing look fine no wear on the titanium retainers and i have about 20k on the valvetrain. hope this helps. good luck with ur build
Old Dec 2, 2006 | 05:02 AM
really umm... maybe then i should look into supertech
is anyone else running supertech and how many miles have you had and how the wear
also to player5530 how do you nspected the valvetrain did you measure the thinkness of the retainer compared to a new one to se if wearing fast or not thanks
Old Dec 6, 2006 | 01:48 PM
Player5530's Avatar
yea i have 4 sets of valvetrains at my house so i just mic.ed it and compared the numbers to the new valve train. i also looked for any physical wear where the two metals would meet, i did not see any scars. Im up grading to there new TI retainers which are a little taller and thinner where the spring makes contact. ***** at supertech explained the science behind the new retainers. they are suppose to put less spring tension on the valve train or some thing of the sort. call him he can explain it better than me.
bpoweredeg6
26
Jan 25, 2011 06:14 AM
levee000
12
Aug 28, 2008 04:03 PM
kyle-Lst
Jun 6, 2007 11:23 AM
dohcsideSi
Dec 5, 2001 03:14 PM
dohcsideSi
Dec 5, 2001 06:40 AM
