what does '' FRM bores need to be sleeved for best results'' mean ???
Old Nov 29, 2006 | 10:38 AM
yellowturbo's Avatar
Default what does '' FRM bores need to be sleeved for best results'' mean ???
Well I read this on the WISECO pistons website and I dont know what they mean ?? Its only for a few model of pistons like the one for the K20 ???
http://www.wiseco.com/PDFs/Cat...a.pdf
Maybe someone know what it mean ?
Thanks a lot !
Old Nov 29, 2006 | 10:42 AM
ZacCarter's Avatar
FRM+forge pistons=kaboom
H22's have frm as well.
Old Nov 29, 2006 | 11:12 AM
I want to know what FRM mean... lol
Old Nov 29, 2006 | 11:13 AM
mike1114's Avatar
Default Re: (ZacCarter)
some honda motors have a fiber composite type material in their sleeves that takes a special piston. Regular pistons in these cylinders would ruin the cylinders VERY quickly.
Old Nov 29, 2006 | 11:46 AM
quicksilver1689's Avatar
i ♥ snails
frm= fiber reinforced material.
Old Nov 29, 2006 | 12:52 PM
F20Cteg's Avatar
Default Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">frm= fiber reinforced material.</TD></TR></TABLE>
FRM = Fiber Reinforced Metal, technically.
Old Nov 30, 2006 | 07:10 AM
so does it mean that you cant use a forged piston like the Wiseco in a stock K20A2 block ?
thanks for the help guys.
Old Nov 30, 2006 | 07:12 AM
pheurton-skeurto's Avatar
yes, you cannot use a forged piston with the H22/23 and any other motor with the FRM sleeves. there are a bunch of threads on H-T on the matter. search the prelude forum...
Old Nov 30, 2006 | 08:12 AM
blundar's Avatar
I've tuned several H22s with Mahle pistons in them. They didn't seem like they had any unusual issues or shortened lifespans.
Old Nov 30, 2006 | 08:54 AM
sewell94's Avatar
No issues with the mahles here, Blundar actually tuned one of my customers cars with the h22 mahles, it has about 20k on the motor still runs great.
Old Nov 30, 2006 | 08:59 AM
ZacCarter's Avatar
mahles forged?
im talking about K20A2.... does anyone have forged pistons in there K20 ?
Old Nov 30, 2006 | 10:28 AM
Muckman's Avatar
Moderator in Chief
Default Re: what does '' FRM bores need to be sleeved for best results'' mean ???
Why?
Old Nov 30, 2006 | 12:45 PM
Default Re: what does '' FRM bores need to be sleeved for best results'' mean ??? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Why?</TD></TR></TABLE>
because on the Wiseco website there is a mention that the k20 need to be sleeved for best result... just see in the application page. Its a PDF format.
Old Nov 30, 2006 | 12:50 PM
RyanEJ8's Avatar
Default Re: what does '' FRM bores need to be sleeved for best results'' mean ??? (yellowturbo)
The F20C also has the FRM cylinder walls.
Old Nov 30, 2006 | 01:23 PM
d16dcoe45's Avatar
Default Re: what does '' FRM bores need to be sleeved for best results'' mean ??? (RyanEJ8)
The Mahles are specifically made for FRM sleeves. They are actually coated with iron which protects the FRM from the aluminum in the pistons. I believe the stock pistons on an FRM block also have the iron coating. You will get some life out of a normal forged piston on an FRM but they seem to start burning oil within 10,000-15,000 miles.
Old Nov 30, 2006 | 01:55 PM
Muckman's Avatar
Moderator in Chief
No no no. WHY is running forged pistons with FRM sleeves bad? We all know its bad but WHY? Im trying to understand why.
Old Nov 30, 2006 | 06:02 PM
JDogg's Avatar
2 similar metals rubbing against each other gall them selves... aluminum pistons + aluminum bores = bad
Old Nov 30, 2006 | 07:25 PM
earl's Avatar
Default Re: what does '' FRM bores need to be sleeved for best results'' mean ??? (JDogg)
How do you explain the aluminum Mahle pistons that are supposed to work with FRM bores? I always thought it was the rings that tore up the cylinder walls but I am not sure.
Old Nov 30, 2006 | 07:30 PM
JDogg's Avatar
Default Re: what does '' FRM bores need to be sleeved for best results'' mean ??? (earl)
from all the torn up h22's i have seen its the pistons.. otherwise just use some stock rings on some forged pistons and let it roll... the wrong rings CAN tear up the cylinder walls though, i have seen people use shitty aftermarket rings on a "stock" rebuild and tear the cylinders up.
the mahle pistons have a graphite coating and do not expand nearly as much as normal forged pistons, they also have a specific shape to them that helps.
the first h22 we tested w/mahle pistons showed zero material transfer from the cylinder wall to the piston.
Old Nov 30, 2006 | 08:02 PM
earl's Avatar
It is true that Mahle, SRP and SuperTech Pistons are made from a different aluminum compound than all the other forged pistons
Old Nov 30, 2006 | 08:18 PM
JDogg's Avatar
i dont know about supertech or srp ( i never use either of those), but yeah.. mahle pistons have more silicone in them so they dont have as much expansion. more of an OE thing than an aftermarket thing. OE's are conserned with the pistons being quiet. the alloy, i forget the exact number, is technically weaker than alloy's with less silicone, but i havent seen where it matters.
Old Nov 30, 2006 | 10:06 PM
Adi Radoncic's Avatar
On Fire!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowturbo &raquo;</TD></TR><TR><TD CLASS="quote">
because on the Wiseco website there is a mention that the k20 need to be sleeved for best result... just see in the application page. Its a PDF format.</TD></TR></TABLE>
You can run them on a k-series no problem, I don't know why wiseco put that **** in their k-series piston catalogue.
Old Dec 1, 2006 | 06:42 AM
sewell94's Avatar
The mahles do have have a higher silicone content but they have some special patented high silicone alloy that is strong as anything else out there, they use it in the alot in the big boy racing stuff. I'm a Porsche man at heart so i've been using mahles for quite a while w/o any problems.
Old Dec 1, 2006 | 07:30 AM
JDogg's Avatar
Default Re: (sewell94)
yep, i have a couple of f1 or IRL (not sure which) toyota pistons as well as a couple of nascar pistons that mahle gave me
kick *** paper weights
