have b18a1, wondering about compatability?
Old Nov 29, 2006 | 08:18 AM
patrickcrx's Avatar
Default have b18a1, wondering about compatability?
i have and ls block from a 92 integra and am building an ls vtec. my block is almost finished but i still need a vtec oil pump. my question is which pump will work with a 92 block. all the pumps ive found will only work as far back as 96. should i start looking into jdm first gen b16 oil pumps?
Old Nov 29, 2006 | 10:02 AM
Fr8nknsteinedCR's Avatar
Default Re: have b18a1, wondering about compatability? (patrickcrx)
Use a gsr or itr(integra type r) oil pump for ls/vtec builds. works fine. I have a gsr one on a b18a block and from what ive heard gsr and itr oil pumps are the same except itr slightly more oil flow from what i know. also if you purchase an obd2 oil pump you have to change the lower timing case cover.
Old Nov 29, 2006 | 10:12 AM
let me rephrase myself because I actually argued with a mechanic on the itr/gsr oil pump issue. and he said it flows more but i found this link and they are saying it puts out the same amount of oil. There are to many contradictions when looking for the proper information. heres the link.. https://honda-tech.com/zerothread?id=909108
Old Nov 29, 2006 | 10:31 AM
doood's Avatar
been there done that
Default Re: have b18a1, wondering about compatability? (Fr8nknsteinedCR)
itr and gsr pumps share the same part #. i dont see how the itr piece will flow any more.
Old Nov 29, 2006 | 11:16 AM
Death_to_Thieves's Avatar
Default Re: have b18a1, wondering about compatability? (that one doood)
the the original poster, all info regarding LS VTEC builds can be found in bambam's very informative thread. check it out.
JDM_home
Jul 17, 2012 06:38 PM
MasterLsGod
Oct 24, 2009 05:02 PM
kikwear002
Jan 26, 2005 08:08 AM
Dragger817
Sep 11, 2003 11:33 PM
