Okay so ive searched in need of a swap expert
Old Nov 29, 2006 | 07:03 AM
s_vares's Avatar
Default Okay so ive searched in need of a swap expert
Well the 3 bolts under timing cover for the motor mount got stripped.
this is a b18. I drilled and tapped the bolt holes.
What i need to know is the overall length of these 3 bolts. (timing motor mount ones)
I know 2 are one size and the 3rd is diff.
so if you guys got em kicking around and wanna trow a tape on them id be grateful.
Thanks
STeve
Old Nov 29, 2006 | 07:10 AM
s_vares's Avatar
Default Re: Okay so ive searched in need of a swap expert (s_vares)
OR
im aware of how deep they need to be in the block if you can provide me with the length of the holes in the mount that would be good too
Old Nov 29, 2006 | 07:29 AM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s_vares &raquo;</TD></TR><TR><TD CLASS="quote">OR
im aware of how deep they need to be in the block if you can provide me with the length of the holes in the mount that would be good too </TD></TR></TABLE>
Unfortunately I don't have these particular bolts available. Somebody help this man. This is a technicial question that doesn't revolve around JDM ashtrays and ****. I know someone has these bolts.
I'll look in the Helms real quick and see if I can find it.
Old Nov 29, 2006 | 07:33 AM
s_vares's Avatar
THanks im gonna tackle swap tonight and wanna have bolts ready. Help..
i need a jdm ashtray too lol jk
Old Nov 29, 2006 | 07:34 AM
Unceasing Measure
Default Re: Okay so ive searched in need of a swap expert (Archidictus)
We-todd is down right now, so I uploaded it to myspace
Old Nov 29, 2006 | 07:39 AM
s_vares's Avatar
WOW. Thank you so much.
im not a tool just didnt find this info well.
Thanks
Old Nov 29, 2006 | 08:06 AM
miahmouse's Avatar
Default Re: (s_vares)
10mm is the width of the bolt, not the length...
Old Nov 29, 2006 | 08:32 AM
s_vares's Avatar
damn
Old Nov 29, 2006 | 08:34 AM
miahmouse's Avatar
call up the stealership... they've got complete specs on the bolts...
Old Nov 29, 2006 | 08:56 AM
Unceasing Measure
Default Re: (miahmouse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahmouse &raquo;</TD></TR><TR><TD CLASS="quote">10mm is the width of the bolt, not the length...</TD></TR></TABLE>
I was hoping the picture would give him enough of a frame of reference to figure the rough length of the bolt from what he has to work with. It's seldom that you can find bolt lengths in the Helms, unfortunately
Old Nov 29, 2006 | 10:22 AM
s_vares's Avatar
you guys are my friends
Old Nov 29, 2006 | 11:20 AM
93egsir's Avatar
I drilled and tapped my same mount holes and they kept tearing out
so I went up in size and that did the same thing.
then I got steel threaded inserts and pushed those into the block and had a shop weld a ring around the hole so they wouldnt pull out.
that has been fine now for 2 yrs
so be carefull that you don't start throwing bolts out from under the car like I did every time they let loose
kind of off topic but I dont have the bolt size
Old Nov 29, 2006 | 11:38 AM
Sloshy's Avatar
damn dude that sucks i went thru the same i used heli-coil, its working good so far its been 6 months or so..
i got those bolt brand new at home i can take picture of them next to a measuring tape BUT when i bought them i got them for my gsr so i dont know if they're different lenght the a b18
Rtboy10
Jun 19, 2009 01:45 PM
Kingkoopa20
Aug 27, 2008 07:02 AM
2slowgsx
Oct 30, 2007 08:30 AM
S9i1R
Oct 3, 2005 03:27 PM
qwklude82
Dec 28, 2002 05:44 AM
