Type-R Door Panel Switches Problem...
Old Nov 29, 2006 | 06:25 AM
Kamikaze's Avatar
Default Type-R Door Panel Switches Problem...
I just put type-r door panels in my LS, and the drivers side is not letting down the passenger side window is it powering the mirrors... Do I have to do some sort of conversion or use the switch from my LS in the door panels? Any help on this? I did try searching...
Old Nov 29, 2006 | 03:35 PM
JDM_DC4_Fanatic's Avatar
Default Re: Type-R Door Panel Switches Problem... (Kamikaze)
are you using the switches from YOUR car, or the switches from the new door panel. I Belive that they are the same, either way, there is no harness converter for the switches.
Old Nov 30, 2006 | 06:48 AM
Kamikaze's Avatar
Using the ones from the new door panels. I was wondering if there was some difference in them. Guess not maybe it's fuse checking time..
Old Nov 30, 2006 | 11:30 AM
Naruto's Avatar
Default Re: (Kamikaze)
Why not try using the switches from your old panels since you know they were working?
ndccpf1
Oct 19, 2018 01:17 AM
suhteevin
Jan 6, 2009 09:04 PM
lPat
Jan 12, 2008 09:43 AM
ALF
Jun 11, 2003 03:19 PM
