Using P73 ITR ecu in B18C ITR swap in OBD1 eg6???HELP????
Old Nov 29, 2006 | 01:08 AM
andybuk's Avatar
Default USING P73 ITR ECU IN B18C ITR SWAP INTO OBD1 EG6 ????HELP????
Hoping somebody can answer this that has actually done this swap.
I am about to swap a B18C ITR motor into my jdm eg6.
I currently have a B16A in the car and is OBD1.
Is it possible for me to just use the ITR engine loom and plug into shock towers and get a OBD1 to OBD2a conversion harness to run the OBD2 P73 ITR ecu in my civic without any engine check lights or problems.
I have Knock sensor, Oil pressure and vtec wires already in the loom.
What about IAB?
I Want to use the P73 ITR ecu not hondata or any other chipped ecu.
All help appreciated.
Old Nov 29, 2006 | 05:27 PM
yaya's Avatar
Default Re: USING P73 ITR ECU IN B18C ITR SWAP INTO OBD1 EG6 ????HELP???? (andybuk)
your harness that goes throught the dash is not obd2. is there even such a thing as obd1 to odb2 adapter? you will be missing connections through the firewall.
you have an actual jdm eg6?
Old Dec 1, 2006 | 12:51 AM
RIP V8s's Avatar
Default Re: USING P73 ITR ECU IN B18C ITR SWAP INTO OBD1 EG6 ????HELP???? (yaya)
i was running a p73 in my eg... bought the car like that but there was a reverse jumper by the ecu..... nice avatar
b18c eJ1
Mar 21, 2007 06:17 PM
andybuk
Nov 30, 2006 02:08 PM
kool168
Nov 27, 2003 01:12 AM
Ryu
Jan 29, 2003 10:10 AM
HYBRIDHATCH92
Mar 15, 2002 07:44 PM
