D2S or D2R bulbs with OEM HID + Casper Shields?
Old Nov 28, 2006 | 11:04 PM
invisible's Avatar
Default D2S or D2R bulbs with OEM HID + Casper Shields?
What bulbs is recommended to use with OEM HID's and casper shields, D2R or D2S bulbs?
Old Nov 29, 2006 | 01:02 AM
MiX's Avatar
MiX
Default Re: D2S or D2R bulbs with OEM HID + Casper Shields? (Battle23)
D2S are for projectors and D2R are for relector housings. So if you are using a casper shield i am assuming you are using a relector housing opposed to a projector. So you would want a D2R bulb.
fyi only difference is a d2r bulb has a shield on it while the other one doesnt.
Old Nov 29, 2006 | 06:12 AM
invisible's Avatar
Default Re: D2S or D2R bulbs with OEM HID + Casper Shields? (MiX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiX &raquo;</TD></TR><TR><TD CLASS="quote">D2S are for projectors and D2R are for relector housings. So if you are using a casper shield i am assuming you are using a relector housing opposed to a projector. So you would want a D2R bulb.
fyi only difference is a d2r bulb has a shield on it while the other one doesnt. </TD></TR></TABLE>
Yeah I know. I just wanted to know which was used for casper shields.
Old Nov 29, 2006 | 10:49 AM
MiX's Avatar
MiX
well u should only be using casper shields in reflector housing so D2R is your answer.
Old Nov 29, 2006 | 11:35 AM
invisible's Avatar
Default Re: (MiX)
What's the difference between them, other than D2R's go in relector housing and D2S go in projector?
Old Nov 29, 2006 | 07:41 PM
MiX's Avatar
MiX
no offense but please read my post before you ask questions b/c you have now asked 2 more questions when i have already answered both them . READ DAMMNIT. sorry just ranting.
QUOTE: " fyi only difference is a d2r bulb has a shield on it while the other one doesnt. "
To explain further, the d2r bulb has this black part on it that prevents light from spreading in all directions, while the d2s does not have this b/c they belong in projectors, and projectors aim the light beam, so you want as much light possible in all directions.
Old Nov 29, 2006 | 07:42 PM
MiX's Avatar
MiX
d2s bulbs in a reflector housing will produce unwanted light.
Unwanted light - yellow light, basically light that is being refracted off the back of the housing.
Old Nov 29, 2006 | 07:52 PM
invisible's Avatar
Default Re: (MiX)
thanks
TurbothisLS
Sep 30, 2016 08:42 AM
Accord1234
Lighting
10
Jun 7, 2008 07:28 AM
NorthernXposure
Dec 9, 2007 08:50 PM
JforJonathan
Mar 13, 2004 01:10 PM
BlazinITR
Nov 21, 2001 07:32 PM
