CABLE TRANNY!!!!
Old Nov 28, 2006 | 09:54 PM
geces23's Avatar
Default CABLE TRANNY!!!!
ok heres the deal....
i have a b16a in my 93 integra and i got a Y1 cable tranny with it...
so i got the thing and i was assuming that the cable is brand new...
the swap was done at a local shop...
so now i smell my clutch burning
and its running a excedy stage one clutch
my clutch pedal has a little delay before disengaging
so i hit the freeplay then it engages
then when the shift is over
it does not disengage wen i let off
but yet it sticks to the floor and stay engage for a couple of seconds
could it be the cable???
Old Nov 28, 2006 | 09:57 PM
b18cda6's Avatar
Default Re: CABLE TRANNY!!!! (geces23)
you can adjust the cable at the tranny mounting point.. sounds to me like it may be a lil on the tight side.. allowing the clutch to not fully disengage... either that or your cable is stretched, its hit or miss with da clutch cables, some people snap em all the time and some last for a good amount of time... ( i dont get it either)
Old Nov 28, 2006 | 10:05 PM
geces23's Avatar
so what would i do if its stretched????
and what do you mean "its hit"
Old Nov 28, 2006 | 10:08 PM
GoldCoin's Avatar
Default Re: (geces23)
either you get it or you dont. ie"hit or miss"
Old Nov 28, 2006 | 10:10 PM
geces23's Avatar
aight..
i had to kinda read it more then five times....
so now...if it is stretched
what do i do???
losen it or tightin it???
Old Nov 29, 2006 | 07:10 PM
b18cda6's Avatar
if it is slipping, and smelling like burnt clutch, loosen the cable up a tad..
sounds like the clutch is not fully engaging when you let the pedal out..
Old Nov 29, 2006 | 07:31 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (b18cda6)
yea...adjust the cable BUT don't go all crazy turning it and whatnot....adjust it a little bit then try out the feel and so forth until its where you want it
Old Nov 29, 2006 | 08:17 PM
cranny's Avatar
24.224.233.247
Default Re: (GRAF-FITI)
you set a clutch by freeplay. should be a half inch at the very top of the peddle that does nothing when you push that distance. that and reach down with your hand on the clutch arm itself , shyould be able to wiggle it a little. peddle should grab approx halfway up. and be fully engaged at 3/4.
hondateg10
Aug 14, 2007 12:00 PM
synner
Aug 6, 2006 12:09 PM
spooncivic01
Jul 8, 2006 06:13 AM
Sirex
Sep 26, 2003 07:55 AM
