acura integra 98 car audio diagram
alright i cut my stock adapter and i bought a new alpine deck. i was wonderin if anyone knows the diagram to directly install the deck to the stock wire harness withoujt adapters. someone please help
Memory (+12v Constant) Blue/White
Ignition (+12v Switched) Yellow/Red
Ground (-) Black
Illumination Red/Black
Dimmer (none)
Power Antenna Yellow/White
Left Front Speaker (+) Blue/Green
Left Front Speaker (-) Gray/Black
Right Front Speaker (+) Red/Green
Right Front Speaker (-) Brown/Black
Left Rear Speaker (+) Blue/Yellow
Left Rear Speaker (-) Gray/White
Right Rear Speaker (+) Red/Yellow
Right Rear Speaker (-) Brown/White
Ground (-) Black
Dimmer (none)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI »</TD></TR><TR><TD CLASS="quote">Memory (+12v Constant) Blue/White
Ground (-) Black
Dimmer (none)
hm.. how come http://www.installdr.com integra 98+ diagram shows that the 12+v battery wire is white with yelow stripe when u say blue with white stripe. and i dont think i even see a white wire with yellow or blue with whtie stripe in the stock harness.. thats the only wire confusing me.. someone help? and when i install an alpine deck do i have to install a new ground wire from the deck?
Ground (-) Black
Dimmer (none)
Ground (-) Black
Dimmer (none)
i think mixed up the power wire with antenna wire.
Ground (-) Black
Dimmer (none)
uh.. so is the http://www.installdr.com one right? but i dont think i can find the white with yellow stripe wire.. because i tried connecting it but it doesnte ven turn on, i connected the black wire with black cuhz thats ground but do i also have to ground it somewhere else? someone please help this my first time installing a deck and the stock adapter was cut..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Geeezer »</TD></TR><TR><TD CLASS="quote">
i think mixed up the power wire with antenna wire.</TD></TR></TABLE>
I'm sorry, you are right. just refered to my factory service manual. my bad.
