water pump OEM or Aftermarket??
Old Nov 28, 2006 | 05:28 PM
hella_usdm's Avatar
Default water pump OEM or Aftermarket??
My water pump is leaking and I need to know if an aftermarket one is better or the oem one. I just replaced it 45,000 miles ago and its leaking, so I'm thinking I'll bite the bullet on the oem one since the first one that was installed was aftermarket. Thoughts?
And is this something I could do myself? Does the axle need to be pulled off? What are some of the "harder" things I would encounter?
SteveoBA8's Avatar
Default Re: water pump OEM or Aftermarket?? (hella_usdm)
OEM
Old Nov 28, 2006 | 05:29 PM
AndyD's Avatar
OEM.
When it comes to water pumps and timing belts, I ALWAYS recommend OEM. They all have a proven track record. Going with anything else is just asking for trouble.
Old Nov 28, 2006 | 05:33 PM
hella_usdm's Avatar
ok oem it is, should I replace the timing belt while it apart, it was replaced at the same time as the pump.
What else can I replace while I'm in there. The balance shaft seals/retainers were all already replaced 10k ago.
Is there a crankshaft seal in there?
Old Nov 28, 2006 | 09:36 PM
lude98SH's Avatar
Default Re: water pump OEM or Aftermarket?? (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">OEM.
When it comes to water pumps and timing belts, I ALWAYS recommend OEM. They all have a proven track record. Going with anything else is just asking for trouble.</TD></TR></TABLE>
How are the electrical water pumps ? Ive seen them before I forget who makes them ?
Old Nov 28, 2006 | 09:44 PM
Hawkze_2.3's Avatar
Default Re: water pump OEM or Aftermarket?? (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">
How are the electrical water pumps ? Ive seen them before I forget who makes them ? </TD></TR></TABLE>
Meziere ...from everything I've read they work, but are lots of headaches.
Old Nov 29, 2006 | 03:46 AM
lude98SH's Avatar
Default Re: water pump OEM or Aftermarket?? (Hawkze_2.3)
What gains are to be acheived ? Im guessing just reduction of the rotating mass....right ?
Old Nov 29, 2006 | 07:39 AM
Hawkze_2.3's Avatar
Whatever drag the water pump would put on the engine is gone...probably a pretty small % increase. Not so much the weight or mass of the pump...
Old Nov 29, 2006 | 01:49 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Oem is overated. No OEM 's produce their own parts. There are many quality parts out there for less the price of stealership parts. In fact people on this board replace there parts with non-oem parts all the time. Do you all beleive performance parts are the only parts with quality inspection. HA!! Most of those so called performance parts you all buy were made oversea's were the labor is cheap and the inspections are nil.
Old Nov 29, 2006 | 05:49 PM
yOnKiNaToR's Avatar
Default Re: water pump OEM or Aftermarket?? (cb7-R)
i've had all oems in my hondas and they've all lasted over 100,000 miles. i go with proven reseults.
NUT-018
Sep 23, 2012 04:52 AM
91GEDHATCH
16
Dec 22, 2010 07:05 AM
barrera
Jan 2, 2010 03:09 PM
Capsule Kid
Aug 9, 2005 01:20 PM
mingbling
10
Aug 6, 2004 08:39 AM
