F22 block + H22 head, will it get lower or higher compression?
Old Nov 28, 2006 | 04:32 PM
dpine's Avatar
Default F22 block + H22 head, will it get lower or higher compression?
with an all stock components f22 block (I think 8.8 compression) with an h22 head installed will my static compression be lower or higher?
Thanks
Old Nov 28, 2006 | 06:05 PM
high_revs's Avatar
lower compression...h22 head has more cc's therefore crating bigger space which makes for less compression.
Old Nov 28, 2006 | 07:38 PM
dpine's Avatar
Default Re: (SB tuning)
ok, I am getting to f22 blocks for $50 and I was going to stick some 11.5 :1 standard f22 pistons in and slap an h22a head on.
Old Nov 29, 2006 | 06:07 AM
Prodigal Son's Avatar
Default Re: (dpine)
This is the coolest thing ever. Select the parts you want to use and it will spit out the basic numbers (CR, max piston speed, etc)
http://www.zealautowerks.com/hfseries.html
Old Nov 29, 2006 | 06:58 AM
dpine's Avatar
Default Re: (Prodigal Son)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prodigal Son &raquo;</TD></TR><TR><TD CLASS="quote">This is the coolest thing ever. Select the parts you want to use and it will spit out the basic numbers (CR, max piston speed, etc)
http://www.zealautowerks.com/hfseries.html</TD></TR></TABLE>
Doesn't seam very accurate at all
Old Nov 30, 2006 | 10:27 AM
Snate's Avatar
Default Re: (dpine)
Changing the head on the F22 block won't change the compression at all. I had thought it would raise it, but from what I've read it doesn't change at all. It is still 8.8;1
Too-R3ckl3ss
Apr 1, 2012 12:21 PM
mhlamin
Jun 19, 2008 09:08 AM
Lewdin' Incognito
Jun 27, 2005 04:59 PM
