problem with LS/VTEC hehe..
well the only problem i have is gettin it built..
heres wat i have:
ctr pistons
new gaskets
new timing belt
water and oil pumps from 2000 SI
misc things (spark plugs/wires)
ls/vtec oil line
eagle rods
all id need to do is:
machine the block... bore,hone,fit pistons-press pins to rods-balance
get the rod bearings i need
...then build
anyone in Dallas area want to help my build? wats ur charge..etc.
and no i dont want to go to a performance shop.. more than likely they'll rip me off with labor so on..
i could get the machine shop work done.. along with getting the rod bearings.. so basically i need someone whos willing to piece it together
i have a source who lets me kno wat i NEED.. and hes having trouble gettin someone to build it for me
right now i have a gsr engine.. only prob is in the block but rebuildable if u wanted to keep that as a project hehe + cash ofcourse <-- wat i can offer hehe
thats another reason i wouldnt go to a shop.. im sure they are not interested in a trade lyk that.. and some can be scandalous
anyways let me kno..
thx
[Modified by xFlipNotiKx, 12:28 AM 5/11/2002]
heres wat i have:
ctr pistons
new gaskets
new timing belt
ls/vtec oil line
eagle rods
...then build
thx
Did you get over sized CTR pistons?
Don't shot-peen your rods! Iv reasearched the **** out of it, its not worth it, mor then likly you will just mess them up. Just get ARP rod bolts and call it good. Other then the bolt, the ls rod is very good.
Order a helms manual, it will explain all about which bearings you need and so forth.
well the pistons wouldnt actually make a good fit into the motor so the block has to be bored
as far as the rods.. someone told me the eagle rods would not fit without modification in the machine shop to my CTR pistons
so thats y i should just go ahead and shotpeen the rods
well hmm can anyone let me kno about how much it would cost to do the following things?:
bore block for CTR pistons (.25mm?)
have pins pressed?
again.. if anyone in dallas area wants to work on this project.. how much they would charge? hehe
have pins pressed?
I don't know the prices for your area,
I was quoted:
$90 for a bore, hone, and fitment of the pistons
$25 to have piston pins pressed onto rods
$125 to balence complet rotaiting mass (crand, pistons, rods, pully, flywheel, ect...)
I was quoted:
hmm...ima try to get to a machine shop and bore, hone and fit pistons.. and have the pins pressed onto the rods
also.. anyone kno for SURE which rod bearings to get? .. i heard green.. just want to make sure thats right
and then it should be ready to piece together
thanks
thanks
just a quick question.. Wont putting a piston from a short stroke motor into a longer stroke motor like an LS make the compression ratio really really high??? Im guessing that the compression is gonna be somewhere in the 12:1 or higher....
I'm not flaming, but you MUST get a helms manual. It will explain which bearings you need. None of us here can help you there; we need the numbers/letters off your block and crank. Also, you need the manual for the torques specs. I paid 64 eached (I bought an integra and civic/del sol one) shipped for mine. My ls/vtec was the first autowork I've done. It's easy, just get the helms, tools, and lots of patience.
The price for the bore and hone is a bit high. I paid 40 for mine. I would get a b18c or c5 oil pump. You didn't have vtec head studs or bolts. For studs, get the ones for the gsr.
There are plenty of writeup out there. Type C has a very complete on the hybrid board. C-speedracing also has good writeups. Between the net and the helms, you should have all the info you need.
Good luck!
Good luck.
Good luck!
Good luck.
hmm well ill head to the machine shop and ask them to get the numbers and letters for me..
and id rather not mess with my car.. and let a professional deal with it hehe..
man dont listen to any of those fools ill do the swap for you, if its to damn easy ive got it in my 96 hatch. ive got lsvtec with type r cams b16a pistons and so on and so on. im out of ft worth and it would only take a day or so if you already have the ****. just mail me at dabeast700@yahoo.com to get a hold of me.
