B16 Build or LS V-TEC Which is going to make more power?
Old Nov 28, 2006 | 03:26 PM
blinddan's Avatar
Default B16 Build or LS V-TEC Which is going to make more power?
OK i have a B16 from a 00 Civic and it is just about ready for a rebuild, The question is should i just get an LS block and build it into an LS V-Tec or take the B16 and Bore 20 over and stroke it?
Any info is a great help and if anyone has truly a good deal on some piston and rods let me know
Thanx
Old Nov 28, 2006 | 03:28 PM
BILLY_BLING's Avatar
go with a b20vtec you will love it!!!!!!!
Old Nov 28, 2006 | 03:30 PM
xDicktonesx's Avatar
Default Re: B16 Build or LS V-TEC Which is going to make more power? (blinddan)
destroke it to a B13...but wait, then it would be a early 90's sentra chassis. crap!
Old Nov 28, 2006 | 03:40 PM
blinddan's Avatar
Default Re: (BILLY_BLING)
well i was hopeing to stick with the b block, If i was going to really change things then i would get a k20 and kick alot of ***
Old Nov 28, 2006 | 04:05 PM
blinddan's Avatar
Default Re: (blinddan)
thats it no one can help me with this?
Old Nov 28, 2006 | 04:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinddan &raquo;</TD></TR><TR><TD CLASS="quote">thats it no one can help me with this? </TD></TR></TABLE>
its not that no one can or cant help you, it is just that they are reluctant to help:
a. someone asking such a stupid question
b. someone who is not willing to search and draw their own conclusion and would rather let HT people tell them what to do with their car
c. someone with something as lame as you in your sig.
short answer is, there is no replacement for displacement, even in the honda world and anyone who chooses an 77.4mm crank over a 89mm crank for an NA build isnt thinking with their head.
what do you plan to "stroke" the b16 with? my suggestion for you in particular is to find a gsr short block an plop your b16 head on it and call it a day.
Old Nov 29, 2006 | 10:29 AM
Mike@K-Tuned's Avatar
Default Re: (xDEFTONESx)
Use the Search function next time and you won't need to wear a flamesuit when you post. There are plenty of B16 and LSV builds in here. Do some research and you'll be fine.
Old Nov 29, 2006 | 11:34 AM
MR_Ek4's Avatar
Default Re: (LSvtecMike)
You can make just as much power with a b16 as with a ls-v or b20-v its just how much money you are willing to spend you have to be more elaborate
Old Nov 30, 2006 | 01:31 PM
blinddan's Avatar
Default Re: (EM1_00MRBuilt)
ok thanx for the help.... But the rude comment was not necessary.
In my area i am very well known for building (at the time ) 1 Of the fast SOHC Turbo Civic, Now i am shure there are alot faster now, I have been working on cars for 15 years ,Alll turbo, so again that coment was not warrented.
I just wanted alittle direction
Well Thanx again
Modified by blinddan at 1:44 AM 1/16/2007
Old Nov 30, 2006 | 02:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinddan &raquo;</TD></TR><TR><TD CLASS="quote">ok thanx for the help.... But the rud comment was not necessary.
Well Thanx again</TD></TR></TABLE>
will you autograph my **** with a sharpie marker? ill never wash them again.
Old Nov 30, 2006 | 07:42 PM
My opinion is that a simple oem built LSV will be more cost effective if your looking for something with some good power. I think to try and make the same power with a B16, you would need to put in a fair bit more time and money. Other members opinions may differ on this. Here are two really good threads on LSV's, I hope they can help you out some.
https://honda-tech.com/zerothread?id=1676914
https://honda-tech.com/zerothread?id=1812388
Just a thought: You might want to consider changing your sig, especially if your going to post in the AM forum. Some people like boost better some prefer AM, but lets not bash on each others preferences or opinions. Just my opinion.
Old Dec 1, 2006 | 01:33 PM
blinddan's Avatar
Cool Thanx for the link i found it very help full.... Yes next time i will search a lot more
Old Dec 1, 2006 | 08:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinddan &raquo;</TD></TR><TR><TD CLASS="quote">Cool Thanx for the link i found it very help full.... Yes next time i will search a lot more </TD></TR></TABLE>
No problem, good luck with your next build, whatever it might be.
Old Jan 15, 2007 | 04:46 PM
George Knighton's Avatar
H-T Order of Merit
will you autograph my **** with a sharpie marker? ill never wash them again.</TD></TR></TABLE>
Could you please consider toning it down? It seems to me I get at least one post/day about you. God only knows what the other moderators get.
Old Jan 15, 2007 | 05:03 PM
Jdm94siR's Avatar
i think you shoul go with Ls-Vtec. It has a lot more tq. and hp. then a b16. but do some more reserch on how to build it. You dont what to buy the cheap stuff trust me that sheat dont work and you end up spanding you money for nothin. You know that many Ls/vtec's leak oil from under the had gasket. Do some reaserch on that and try to build it carfally so you wold not have to the morot out the second time and re doit. wish you the verry best with the swap.
Old Jan 15, 2007 | 05:07 PM
Default Re: (Jdm94siR)
how about let the 45 day old thread die, especially when there are 4985749837235089 just like it in the archives?
Old Jan 15, 2007 | 05:27 PM
bambam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_00MRBuilt &raquo;</TD></TR><TR><TD CLASS="quote">You can make just as much power with a b16 as with a ls-v or b20-v its just how much money you are willing to spend you have to be more elaborate </TD></TR></TABLE>
You will never make as much power with a 77.4mm crank as you will with an 89 or 87.2mm crank. Thinking so is just plain dumb.
Old Jan 15, 2007 | 09:23 PM
LABjunkies's Avatar
i agree with alot of people are saying, you could make the same power but would cost more money but would be more reliable, just double check with some research and your budget. good luck
Old Feb 15, 2007 | 12:55 PM
b16a4's Avatar
Default Re: B16 Build or LS V-TEC Which is going to make more power? (LABjunkies)
i agree
it will be more reliable with a b16 stroke than a 89mm stroke
Old Feb 15, 2007 | 01:04 PM
kartman5's Avatar
Default Re: B16 Build or LS V-TEC Which is going to make more power? (b16a4)
Building a b16 would give a fun, strong engine - It would simply cost you a
small fortune. At least $6000.00. Good luck!
Old Feb 15, 2007 | 07:04 PM
b16a4's Avatar
Default Re: B16 Build or LS V-TEC Which is going to make more power? (kartman5)
go crvtec!
im going that and i currently have a b16 151whp
ser13
13
Sep 25, 2007 04:09 PM
honda_student
Aug 5, 2007 10:41 PM
awdriscol4
Jan 18, 2005 02:08 PM
eg6T
Nov 24, 2004 07:14 PM
Vtecless212
Apr 5, 2003 12:39 AM
