Suspension & Brakes Theory, alignment, spring rates....
Car ALIGNMENT, is it really align or they say so ?
Old Nov 28, 2006 | 03:18 PM
Kangolbrand's Avatar
Default Car ALIGNMENT, is it really align or they say so ?
Just got my spts at americas tire and i align it at a shop for 50 bucks... kinda worry about it though, i only pay 50 so im not sure if its legit. He said if the car is lower it well never be prefect even with adjustable camber kit. Is this true? I dont want camber wear on my tires... i had wear before cuz i did the align at a cheap shop. Anyways on telling the align is good? .....
o, after he align it I kinda want to lower the front about 3 thread lines from the coilovers... would this affect the align ... do i have to have it redo if i decied to lower my car more?
thanks
Old Nov 28, 2006 | 03:29 PM
chrisw85's Avatar
you wont get adverse tire wear if you get your toe set to 0 all the way around, even if your camber isn't in spec, you lowered your car, you have entirely different spring rates, why do the stock align specs apply? you need different parameters for what you are running and stock doesn't cut it when you are lowered.
Old Nov 28, 2006 | 03:56 PM
Tyson's Avatar
Default Re: Car ALIGNMENT, is it really align or they say so ? (Kangolbrand)
toe is what matters.
and when you change ride heights, you change toe.
think about that for a while.
Old Nov 28, 2006 | 04:25 PM
i got teins coilover4 swith skunk2 pro seriese cambers on the front... what else is better to hlelp this ? ill ask bout the toe. Thanks
Old Nov 28, 2006 | 05:09 PM
JDM_DC4_Fanatic's Avatar
Toe will effect the steering wheel positioning, and it will feather the edges of the tires if its off. The Camber is what will ruin the life of your tires fastest. The lower you drop the car, the more camber you will have, this needs to be corrected. Stock alignment specs WILL work on lowered cars. The steering is designed to work the the FACTORY spec alignment angels, ride height wont effect this. we do quite a few lowered honda's and such, and havent had a comeback for years.
Old Nov 28, 2006 | 05:11 PM
Tyson's Avatar
Default Re: Car ALIGNMENT, is it really align or they say so ? (JDM_DC4_Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">The Camber is what will ruin the life of your tires fastest. ....this needs to be corrected. </TD></TR></TABLE>
i disagree, especially in the case of hondas with double wishbone suspension.
toe is the killer.
when you "fixed" camber, you fixed the toe. which is probably why you dont get comebacks.
i "fix" my toe and never "fix" my camber, and still get even wear.
when my toe is bad, and my camber is good (stock ride height), i get uneven wear.
im not arguing about this. im sure of this. you are free to disagree.
Old Nov 28, 2006 | 05:27 PM
Default Re: Car ALIGNMENT, is it really align or they say so ? (Tyson)
i'm not trying to trash anybody. However, in my personal experience, when a car comes in, not only honda's, but since his is H-T, I will only speak of them, and the camber is out, the toe is usuially out too. This is true, like you stated. You are also right about the toe coming in with the camber, However, putting the camber back into spec doesnt ALWAYS bring the toe into spec, it all depends on how bad it is when it comes in. My basic point is, which I should of been more clean in stating is, a PROPER alignment is deffinatly worth the money, and can maximize the life of your tires.
Old Nov 28, 2006 | 08:33 PM
is adjusting the toe part of an alignment price? or thats another fee?
Old Nov 28, 2006 | 08:50 PM
DFW's Avatar
DFW
Default Re: (Kangolbrand)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kangolbrand &raquo;</TD></TR><TR><TD CLASS="quote">is adjusting the toe part of an alignment price? or thats another fee?</TD></TR></TABLE>
Adjusting toe is part of the alignment. Just remind them to set it to 0º.
Old Nov 28, 2006 | 09:17 PM
thanks, even if its lower it can be set back to 0? I think he said the best he got it was to half a pos one..... ill make sure to tommow by calling him.......he sad i came in with -1
Old Nov 28, 2006 | 09:23 PM
DFW's Avatar
DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kangolbrand &raquo;</TD></TR><TR><TD CLASS="quote">thanks, even if its lower it can be set back to 0? I think he said the best he got it was to half a pos one..... ill make sure to tommow by calling him.......he sad i came in with -1</TD></TR></TABLE>
I have about -2.5º of camber all around and the toe was set at 0.01º all around after alignment.
raphael
Mar 23, 2010 05:31 PM
SoyMilk
Suspension & Brakes
Mar 19, 2007 12:19 AM
brg2nr
Suspension & Brakes
Jan 27, 2005 10:55 PM
Resident Evo
Nov 11, 2004 09:54 PM
Downey
Mar 17, 2003 10:09 PM
