Installed New Intake - What is supposed to plug into it?
Old Nov 28, 2006 | 03:14 PM
m1ndless's Avatar
* B A N N E D *
Default Installed New Intake - What is supposed to plug into it?
I just replaced my stock intake with a SRI, the only thing that was plugged into my stock intake was one hose, connecting to the top of the engine, now with my new intake, it doesnt have a part to plug into. Do I need to cap it off or what?
EDIT: I read the install tut in the faqs... In this picture, it shows the blue hose plugging into where the old one used too..but that hose goes to othet stuff too, should I unplug that or just leave it?
Old Nov 28, 2006 | 04:33 PM
thatasiankidtony's Avatar
Default Re: Installed New Intake - What is supposed to plug into it? (m1ndless)
You cap it off i believe. The intake should already have one. Thats what I did to mine. If i'm wrong someone correct me
Old Nov 28, 2006 | 06:48 PM
m1ndless's Avatar
* B A N N E D *
Default Re: Installed New Intake - What is supposed to plug into it? (thatasiankidtony)
I have the blue hose, but no where to connect it too without unplugging the current one..It seems to run fine with out it.
Old Nov 28, 2006 | 06:57 PM
fw190bvi's Avatar
cap it off. its just a vac line...so as long as its capped itll be fine. i think mine is kinda leaking rightnow actually....i should check that
Old Nov 28, 2006 | 10:07 PM
gosu08's Avatar
if your talking about the one that runs along the firewall then yes you need to cap it off or your car will have a vaccuum leak...it will rev up and down. very annoying. just put a small screw in it and then tape it off and you will be all set thats what i did.
Old Nov 29, 2006 | 12:12 PM
m1ndless's Avatar
* B A N N E D *
Default Re: Installed New Intake - What is supposed to plug into it? (gosu08)
What about the one that orignally connected to the engine? I just cut the small hose they gave me and connected it back to the intake..
iheartrice
10
Sep 17, 2008 07:30 PM
rbizzell30
Jun 13, 2008 03:06 PM
giantgreenhead
Dec 9, 2007 02:24 PM
95-Accord-EX
Jun 4, 2007 05:56 AM
Rick
Aug 26, 2003 10:54 PM
