rlz engineering?
Old Nov 28, 2006 | 01:30 PM
sluggo's Avatar
Default rlz engineering?
I had Brad at rlz do a stage 1 port job on b16head of mine tried pm him no response so , i am just trying to find out if the springs in this head will hold up to skunk pro2s the head was done about a year and half ago but the head has never been used just dont want to mess anything up and if maybe i should switch the springs out
thnx
Old Nov 28, 2006 | 03:29 PM
BILLY_BLING's Avatar
just buy some skunk2 spring to be safe
Old Nov 28, 2006 | 03:57 PM
sluggo's Avatar
Default Re: rlz engineering? (sluggo)
I am thinking about it do i have to use their retainers to
Old Nov 28, 2006 | 04:28 PM
sluggo's Avatar
anybody else with suggestions
Old Nov 28, 2006 | 04:45 PM
MR_Ek4's Avatar
I would find out if they replaced them or not kinda no point in paying for upgraded springs when you possibly have them already
Old Nov 28, 2006 | 04:53 PM
sluggo's Avatar
Default Re: rlz engineering? (EM1_00MRBuilt)
they put new springs in there i know that for sure with new valves and new retainers just not sure what they use
Old Nov 28, 2006 | 05:06 PM
Combustion Contraption's Avatar
Take a spring and retainer to any reputable cylinder head shop in your area and have them test it. Test it @ an installed height of around 1.320" and then subtract the lift of the pro2 to find the pressure of the valve spring at max lift. For example if the pro2 cam has a lift of .500 (i dont know what it is off the top of my head)
1.320 - .500" =.82
Get back to us with numbers.
Old Nov 28, 2006 | 05:39 PM
sluggo's Avatar
Default Re: (Combustion Contraption)
thnx for the help and the formula
Old Nov 29, 2006 | 01:52 AM
sluggo's Avatar
Default Re: (sluggo)
anybody else knows what brad uses
Old Nov 29, 2006 | 10:22 AM
MAX_CFM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sluggo &raquo;</TD></TR><TR><TD CLASS="quote">anybody else knows what brad uses</TD></TR></TABLE>
That Head was built for turbo .. I use2 Springs for turbo apps
If you can Take a picture of the springs in the head I can tell you if it will work for allmotor
If you can come down on the weekend I can swap them out for you No charge ...
Old Nov 29, 2006 | 07:11 PM
sluggo's Avatar
Default Re: (MAX_CFM)
thnx Brad i will make it down their maybe with in the next two weekends appreciate you replying
monster_c
Jan 21, 2012 07:49 PM
all_motorsi
Jun 9, 2011 04:00 PM
hondaholic13
Apr 20, 2011 08:38 AM
brandonschmidt
Dec 25, 2009 05:22 AM
TheLostOne
Dec 11, 2001 05:40 PM
