Hondata S300/ Code CYP (9)
Old Nov 28, 2006 | 01:15 PM
McLude2nR's Avatar
Default Hondata S300/ Code CYP (9)
Setup:
99 Honda Prelude (Built/Turbo)
Engine Management: Hondata S300 (P28 w/ adapter harness)
Ignition: Stock
Distributor: OBD1 adapted (Cylinder Position Sensor/ TDC/ Cam Angle all in distributor.)
Problem:
The code "CYP" or Code 9, which is the cylinder position sensor is coming up in the hondata. Car surges inconsistently (no rhythm) and will not idle properly. The wideband AFR is all over the place no matter what position the throttle is at. We have a very competent tuner on hand, and he has done everthing he can in the hondata to try and get it to run smooth enough to start tuning. For the first 5 seconds that the car is on, it's fine and smooth, after that is when it gets all squirrley. We have checked the wire back to the distributor and it is sending proper signal. I'm thinking the Code and the surging/idling problem may or may not be related. Any Ideas on where else I should look to hunt this problem down?
ef2hondaboi
Jul 21, 2009 06:42 PM
McLude2nR
Nov 29, 2006 05:59 AM
Black DC2
Sep 2, 2005 08:20 PM
seek167
Jul 1, 2002 03:48 AM
