Replaced **ALL** brake light bulbs and yet
Old Nov 28, 2006 | 12:37 PM
HA0LEFIED's Avatar
Default Replaced **ALL** brake light bulbs and yet
... the passenger side brake light doesnt work when i push the pedal (the constant is still on but when i push the pedal it doesn't light up.
Old Nov 28, 2006 | 01:49 PM
Eran's Avatar
HT White Ops
Check the harness for rust or corrosion.
Old Nov 28, 2006 | 02:48 PM
HA0LEFIED's Avatar
none.
Old Nov 28, 2006 | 03:32 PM
dohcdelsol's Avatar
Default Re: (HA0LEFIED)
fuse??
i'd pull it all apart and clean it all just to be sure...
Old Nov 28, 2006 | 08:42 PM
HA0LEFIED's Avatar
are there two fuses for each brake light? its wierd that the constant light is on and not the brake pedal one.
Old Nov 28, 2006 | 08:45 PM
john666's Avatar
Default Re: Replaced **ALL** brake light bulbs and yet (HA0LEFIED)
random question.. do you have the correct bulb ? it should be a bulb with 2 filaments
Old Nov 28, 2008 | 12:55 PM
Bizz's Avatar
Icon3 I have the same problem! Please read...
Some one left us with a broken tail light but the light worked just fine. So we changed the lens, and now when the lights are on the tail light works except when we brake there is no light, this is on the drivers side and on the dash the "rear lamp" indicator is on.
outlawstar27
May 18, 2007 09:04 AM
EASY101
Jul 10, 2006 02:26 PM
tysn
Jan 11, 2006 07:28 PM
97accordse
Jun 18, 2002 06:26 AM
