VictorX and 68mm TB? yay or nay?
my setup consist of..
- M24x's w/ associated valvetrain
- 1mm over valves
- hytech 2.0L header
- 3" exhaust which i will eventually be changing to 2.5"
- Mugen intake
- Wiseco 11.5:1 comp pistons
......etc, but thats the main things.
I was thinking the biggest bottle neck now is the intake manifold and throttle body. Next after that will be the head. Am i correct on this?
I plan to order a VictorX since everything else on the car is geared for top end as well as a Professional Products 68mm ITR throttle body. Or do you think the stock ITR pieces are sufficient?
- 1mm over valves
- Mugen intake
may i know whats ur set up and the hp ur running current cos ur set up sounds like mine and i wanna check if i'm gettig power out from the m24x cam.
With the set-up you have already, if you're not going to invest in the victor x or tb, GO for the a CNC ported intake manifold and ported TB. You'll be extremely happy with just those bolt ons
