engine rpm dropping - 2 questions
ill start off with a little background of this engine in brief
had no oil in it, my music was loud pumping like crazy and i was just crusing, i pull to a gas station to get gas, i hear a loud knock from my engine, i turn it off. tow it home. so i figured my engine = toast. took it apart, changed all the bearings, pistong rings and **** but my crankshaft = fuked. so right now i got a little knocking cuz of the crankshaft.
sometimes when im driving and the rpm is like 2-3k and i floor it the car dont accelerate but i can hear the intake and the exhaust and the car starts to shake as if the clutch is slipping or something, but its not.(and not because rpm is low, just some wierd ****). thats my first question.
my second is. right now i just got home and just b4 i turned my car off the rpm was at like 0.5 and it droped to like .2 car wanted to stall but it didnt, it went back upto .5 then down again wanting to stall but it didnt and the oil light came on flashing, right away i turned it off and came onto my computer to type this up lol
i been driving the fuked engine for 2 weeks now and ima drive it until it complety dies. if anyone knows a temporary fix so that the engine works another couple weeks before i find a new engine type it up :D
actualy i got a nother question too: would 94-97 I4 accord engine bolt in my lude and my tranny?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by farhan445 »</TD></TR><TR><TD CLASS="quote">i been driving the fuked engine for 2 weeks now and ima drive it until it complety dies. if anyone knows a temporary fix so that the engine works another couple weeks before i find a new engine type it up :D
actualy i got a nother question too: would 94-97 I4 accord engine bolt in my lude and my tranny?</TD></TR></TABLE>
Run thicker motor oil. And pray it holds.
And yes, it'll fit. But be slow.
had no oil in it
Errrr.... And why would you drive around with no oil in your engine???
You do know what purpose oil serves in engines, right?
i been driving the fuked engine for 2 weeks now and ima drive it until it complety dies. if anyone knows a temporary fix so that the engine works another couple weeks before i find a new engine type it up :D</TD></TR></TABLE>
Temporary fix??? Sure... just slap a typeR sticker on the valve cover, turn your stereo volume all the way up sO iTs pUmPiN LiEk CraaaZy, and rev the expletive out of it. Oh, and don't forget to drain the oil completely (to the last drop). That should do it
P.S. put your flame suit on, you'll need it.
had no oil in it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by farhan445 »</TD></TR><TR><TD CLASS="quote"> right now i just got home and just b4 i turned my car off the rpm was at like 0.5 </TD></TR></TABLE>
Half a revolution per minute LMAO
So.....overlooking the fact that you had no oil for now, you had the whole engine apart. You replaced pretty much everything inside, put it back together with a known "fuked" crank?
I just want to make sure I am understanding this correctly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by farhan445 »</TD></TR><TR><TD CLASS="quote">had no oil in it....music was loud pumping like crazy.... i turn it off. tow it home.....took it apart, changed all the bearings, pistong rings and **** but my crankshaft = fuked.....knocking cuz of the crankshaft....i floor it....car starts to shake....been driving the fuked engine for 2 weeks</TD></TR></TABLE>
Wow.
um......
wow.
Try this: http://honda-miracles.com
Wow.
um......
wow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GtechPro »</TD></TR><TR><TD CLASS="quote">I doubt that he took the engine apart and put it back together. Any person capable of doing that would replace any known "fuked" parts before putting it back together. Common sense.
Common sense flew out the window when he decided to drive without oil in it.
i check the oil every morning before i start it now lol, i just need a crankshaft.. everything else is fine.. crankshaft for a prelude is a pain in the *** to find where i live.. engine is pain also unless i drive for an hour and half or so to get one from JDM. accord engines are pretty much at every junkyard thats why i asked if i could get one and put in.
