Converting ODB1 D15B to ODB2
Old Nov 28, 2006 | 11:49 AM
redsohc101's Avatar
Default Converting ODB1 D15B to ODB2
Sup H-T,
Failed the Illinois Emissions test yesterday. I swapped my D16y8 for a D15B due to a spun bearing and it was cheap! Problem: I converted the car, 96 Civic EX to ODB1. Replaced the ecu w/ one from Kenji. The car runs great BUT!!! they can't communicate w/ the ecu... My guess, it's cus the scanner is looking for ODB2 and of course... I'm not that!
Has anyone heard or read about converting a D15B into ODB2? The only two sensors needed are the KNOCK SENSOR and the CRANKANGLE SENSOR. Both clips are hanging as they are not in use. I work at a shop and one of my techs say they can tap the block and thread a hole for the knock sensor. My concern is w/ the crank angle sensor. When I get home today from work I'm going to strip dwn the D16y8 and see how I can manipulate an ODB2 version for this D15B
Any input feel free and speak!!!!
Old Nov 29, 2006 | 10:55 AM
redsohc101's Avatar
Default Re: Converting ODB1 D15B to ODB2 (redsohc101)
No comments? Whoa, I thought this would make an interesting topic. Well, I'm still trying to find time to get my hands on my Y8. I'll keep you posted.
Old Dec 4, 2006 | 02:41 PM
redsohc101's Avatar
any1??? BUMP THIS SNIT!!!!
Old Dec 4, 2006 | 03:43 PM
Jonknee's Avatar
dang sounds like a mission haha, bump 4j00
Old Dec 4, 2006 | 05:13 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Converting ODB1 D15B to ODB2 (La-Quiete)
http://www.ff-squad.com/technet/ckftrick.htm
as for the Crank sensor I believe
Old Dec 6, 2006 | 12:26 PM
redsohc101's Avatar
Default Re: Converting ODB1 D15B to ODB2 (HondaPartsHero)
Thanks guys... I'm going to try that tonite. I think this might just work! I'll let you know what happens by the end of tonite!
Old Dec 7, 2006 | 04:40 PM
redsohc101's Avatar
Okay fellas the quick splice connection trick worked! Much props go to HondaPartsHero for the helpful link. So far no CEL and I don't have a knock sensor light on either. I'm going to run a scan on it w/ the shops scanner and see if I can communicate w/ the ECU. If alls well, then, I'm off to the Emissions center in the morning and see if I pass. WISH ME LUCK.
Then, I'll slap my Kenji ecu back on, cus Vtec at 5300 rpms vs 5k feels just a tad bit better!
Thanks again, I'll keep you posted!
TechJohnson
Mar 18, 2016 02:45 AM
CplNet
Engine Management and Tuning
Sep 26, 2010 04:22 PM
jr000
Aug 30, 2007 09:50 AM
THC07
Oct 2, 2005 01:31 PM
vladd
Nov 30, 2002 04:15 PM
