d16y8 manifold question
If you get a 99-00 d16y8 mani make sure the small holes on the intake mounting area are either welded shut or the nipple coming straight up off the mounting face is blocked. Personally I recommend the welding. Also I recommend using your native throttle body....it will work. If you want a clean installation go ahead and get a D16y8 throttle cable as well.
element_1one
Jul 29, 2003 10:47 AM
