how do i find out torque specs??? need ASAP!!
Old Nov 27, 2006 | 09:02 PM
focuz_btch's Avatar
Default how do i find out torque specs??? need ASAP!!
for a 98 Dc2 gsr
so i can install a flywheel?!>!>!
Old Nov 27, 2006 | 09:07 PM
Rikter's Avatar
Call your local dealer.
-Rik
Old Nov 27, 2006 | 09:11 PM
HxC_TegGirl's Avatar
Default Re: how do i find out torque specs??? need ASAP!! (focuz_btch)
looking in my helms manual...
FW bolts are 76 lb/ft
Old Nov 27, 2006 | 09:13 PM
Inner bolts are 76lb/ft and outer bolts that go thru the pressure plate are 19lb/ft.
Old Nov 27, 2006 | 09:20 PM
Old Nov 27, 2006 | 09:21 PM
focuz_btch's Avatar
Default Re: how do i find out torque specs??? need ASAP!! (HxC_TegGirl)
so thats the pounds need to install a flywheel?
on a 98 gsr?
Old Nov 27, 2006 | 09:26 PM
pman44's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by focuz_btch &raquo;</TD></TR><TR><TD CLASS="quote">so thats the pounds need to install a flywheel?
on a 98 gsr?</TD></TR></TABLE>
Yup, that's right. I was just about to post the same, but HxC_TegGirl beat me to it.
Old Nov 27, 2006 | 09:29 PM
I have a helms for a 95 in front of me and the pic came from a 94 helms pdf. I'd assume the specs would be the same for 94-01 LS/GS/RS/GSR.
Old Nov 27, 2006 | 09:32 PM
focuz_btch's Avatar
i wish i knew more **** about cars
i need a mentor.
thanks for the info tho
Old Nov 27, 2006 | 09:37 PM
pman44's Avatar
make sure you tighten them in a criss-cross pattern in multiple steps until the specified torque is reached. do the same when bolting up the pressure plate.
Old Nov 27, 2006 | 09:52 PM
Kafelatte's Avatar
Default Re: how do i find out torque specs??? need ASAP!! (pman44)
i always use the blue locktight on the pressure plate bolt. i know is not necessarily but i just want to be sure.
Old Nov 28, 2006 | 08:50 AM
drumking15's Avatar
id use loctite on the flywheel bolts also...sucks when running a 4pcuk and they back out on ya and have to pull the tranny out all over again....no a prob if you good at them...takes me about 2-3hrs to pull an reinstall
mckenzie
May 23, 2006 11:36 AM
92eh3si
Sep 28, 2004 08:03 PM
ryu12341
Apr 27, 2003 09:02 AM
ryu12341
Apr 17, 2003 12:25 PM
