How to Drain Tranny?
Old Nov 27, 2006 | 06:44 PM
pWebb's Avatar
Default How to Drain Tranny?
well I am very new to Hondas. I took a look under the car and I couldn't find the drain plug on the transmission. Could somebody possible supply a few photos as to where I can locate it? Thanks a bunch!
99 honda accord 4cyl automatic
Old Nov 27, 2006 | 07:09 PM
Homesickelian's Avatar
Default Re: How to Drain Tranny? (pWebb)
please please please try a search when you have such a simple question. So I don't look like a huge ***, here is how you drain the 5th generation.
https://honda-tech.com/zerothread?id=1711883
Not sure how similar it is but if you look hard enough you will find a definite answer
Old Nov 27, 2006 | 07:11 PM
pWebb's Avatar
Default Re: How to Drain Tranny? (Homesickelian)
I searched, but nothing came up. I feel like this question is too simple, and not even talked about.
Old Nov 27, 2006 | 07:15 PM
type drain plug. Check the one I just posted and see if it applies to you, all you have to do is look..
Old Nov 27, 2006 | 07:21 PM
pWebb's Avatar
so, it IS the square shaped one? I tried yanking on it, but I felt like I was going to rip the tranny right out of its mounts. I'll hit it with some PB and try again. Thanks.
Old Nov 27, 2006 | 07:33 PM
thatasiankidtony's Avatar
i don't have any photo's but it is very easy to find it...any ordinary socket should fit in it...
Old Nov 27, 2006 | 09:23 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pWebb &raquo;</TD></TR><TR><TD CLASS="quote">so, it IS the square shaped one? I tried yanking on it, but I felt like I was going to rip the tranny right out of its mounts. I'll hit it with some PB and try again. Thanks.</TD></TR></TABLE>
3/8 drive, counterclock wise, give it a good yank, don't use a breaker bar and slowly turn it, it's very easy to stripe the thread that way.
good jib with a 3/8 wrench
gqstatus05
Sep 23, 2008 04:12 AM
dlinm
May 25, 2007 07:51 PM
H22A4Me
Jan 19, 2006 08:58 PM
dwn4cause
Nov 30, 2004 07:00 AM
cecknight
Nov 8, 2001 10:21 AM
