still won't start. code 15 faulty igniter
Old May 9, 2002 | 01:08 PM
doc804's Avatar
Default still won't start. code 15 faulty igniter
ignition output signal/possible faulty igniter
anyone know if i can use the igniter, and heat sink from a '90 teg. or could it be the coil??? anyone else have this problem.
b16a1 in '90 civic hatch
Old May 9, 2002 | 01:24 PM
Jared's Avatar
Default Re: still won't start. code 15 faulty igniter (doc804)
90% chance its the ignitor. And a 90-91 teg ignitor will work.
Old May 15, 2002 | 07:06 PM
doc804's Avatar
replaced igniter, cap, rotor, plugs, wires and still doesn't kick and still getting same code. igniter wires b15 and b17 are the same for dx, si, and sir so i made no changes. thought about replacing the coil too but unsure about dumping another $50 into the money pitt. it is a dx if that matters to anyone. maybe missing a ground at ecu.
[Modified by doc804, 2:16 AM 5/16/2002]
Jessie127
14
Mar 20, 2011 01:55 PM
FoxRacing254
Dec 12, 2010 07:08 PM
90crvtec
Aug 19, 2005 07:19 PM
dviperbigt
Nov 5, 2004 08:01 PM
importboi22
11
Jun 22, 2004 01:10 PM
