stupid fan question
Old Nov 27, 2006 | 06:37 PM
ludekid4323's Avatar
Default stupid fan question
I just ordered a FAL 12in. LoBoy fan today and I planning on installing it tomorrow. My only question is, how will I know if it works? Is's pretty damn cold right now in PA, and I dont feel like running it hard so how will I know if i wired it up correctly? thanks
Old Nov 27, 2006 | 06:46 PM
petern101's Avatar
Default Re: stupid fan question (ludekid4323)
i think if you turn on your a/c, it should turn on.
or you can go the ghetto route....partially blocking the radiator with a piece of cardboard
Old Nov 27, 2006 | 06:47 PM
Default Re: stupid fan question (petern101)
I guess I'll gotta beez ghetto dawg cuz I removed my ac
Old Nov 27, 2006 | 07:01 PM
Altilude's Avatar
remove the connector to either switch A (thermostat housing) or switch B (next to the headers in that smallish upper rad hose housing), from your engine - and short the connector with a paperclip (essentially you are simulating hot coolant - tricking the ecu that the "switch" has very low resistance - which is what happens when those switches heat up sitting in the coolant) the ecu will instantly run the fan.
(hot coolant) low resitance - fan turns on
(cold coolant) high resistance - fan turns off.
if you short switch B connector your car doesn't even have to be turned on.
that would be the easiest way to instantly make the fans run.
make sure you have the fan configured to pull air thru the rad, not push. (:
Old Nov 27, 2006 | 07:36 PM
bluedlude's Avatar
Default Re: stupid fan question (Altilude)
if its not working, you'll know after about 10 mins of driving. i mistakenly forgot to hook the connector back up to mine and went driving. it drove like CRAP. then i realized what i did.
but thats one hell of a ghetto way to check....
Mfoehrkolb
Honda Civic (2006 - 2015)
May 20, 2018 03:00 PM
hotcivicsi
19
May 15, 2009 01:54 PM
stealth civic
Jan 13, 2005 09:03 AM
