Need help finding out what kind of transmission i have
my tranny says m2y4 but when i gun it both wheels spin at the same time i thought only lsd trannys did that. can anyone tell me thanks
go around a turn fast, at the apex, slam the gas pedal
if you go off the road into a tree, you have an open differential, and that m2y4 would work fine
if you get an erection as you hit the apex and power your way out of the turn you have an lsd in there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever »</TD></TR><TR><TD CLASS="quote">go around a turn fast, at the apex, slam the gas pedal
if you get an erection as you hit the apex and power your way out of the turn you have an lsd in there</TD></TR></TABLE>
spinning both tires does not prove that you have an lsd. the only way is to pull out the axles and look for the bar. I believe bar means no lsd. and no bar means lsd.
