89 Accord EX Carb'd. Choke/vac problem.
Old Nov 27, 2006 | 05:24 PM
DACteg's Avatar
Default 89 Accord EX Carb'd. Choke/vac problem.
Ok, got me a winter beater. The thing ran fine to my house... kinda. but after some investigation i found that it was very, un-responsive. I got new plugs, wires, lubed everything, change fluids, the whole 9 yards.
So i got the problem down the the electronic choke. If i hold the choke open on the car and rev it, it sounds great, but the choke just stays closed if im trying to drive or do anything. it also makes the car jsut die if i dont have the gas pushed in 1/4 way.
Few things i noticed...
The check engine light wont come on, even when jumped
The Gas gauge doesnt work
And the Thermogauge doesnt work.
I am completly stumped. ive reset the ECU as many ways as i can. checked all my pluges i could find. and rearanged the snake pit Honda calls vacuum lines.
Any suggestions here would be great guys, thanks.
Old Nov 27, 2006 | 10:59 PM
DACteg's Avatar
Are there any thermovalves i can adjust or clean?
Old Nov 28, 2006 | 01:43 PM
hondadude's Avatar
Default Re: 89 Accord EX Carb'd. Choke/vac problem. (DACteg)
rearranged the vacum lines? you just hooked them up anywhere?
the original problem sounds like the choke pull off [on the front upper passenger side of the carb body] is bad.
to test it you can remove the breather, plug the vacum connections on the passenger side of the carb. Engine cold running; Use needle nose pliers and pinch off the 2 vacum lines going to the pull off diaphram, the plate should open.
I strongly suggest that you put all the vacum lines back in their original positions.
FYI; Lx not Ex or LXi if fuel injected
Old Nov 28, 2006 | 02:34 PM
carotman's Avatar
You should ask this question at http://www.3geez.com.
There are carb gods there what will surely have the answer to your pain.
jlh911
Jul 13, 2014 11:58 AM
kristens94ex
Aug 27, 2011 09:13 PM
deyomatic
Feb 13, 2008 07:55 AM
mjacbos
Jul 12, 2007 06:10 PM
shawn78
Mar 8, 2007 03:48 PM
