TEST PIPE and NO CEL !!!!!!!!!!!!!!!!!!!!
Old May 9, 2002 | 12:53 PM
comptechgsr2000
Guest
Posts: n/a
Default TEST PIPE and NO CEL !!!!!!!!!!!!!!!!!!!!
If you ever wanted a test pipe without the CEL on you OBD II car look here!
Get a test pipe with out an O2 bunge. Take your O2 sensor and wrap it with tin foil. Then wrap it with electrical tape. Zip tie the O2 onto the sway bar.
The tin foil fools the O2! Amazing but it works.
Just did it on my 2000 gsr and it works!
[Modified by comptechgsr2000, 1:54 PM 5/9/2002]
Old May 9, 2002 | 12:55 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: TEST PIPE and NO CEL !!!!!!!!!!!!!!!!!!!! (comptechgsr2000)
yep, but the tin foil will need to be replaced IIRC.. not 100% sure tho.
Old May 9, 2002 | 12:56 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: TEST PIPE and NO CEL !!!!!!!!!!!!!!!!!!!! (b00st-0wnz)
What is IIRC?
Old May 9, 2002 | 12:57 PM
b00st-0wnz's Avatar
What is IIRC?
If I Recall Correctly.. but like other commonly typed things, the honda-tech ***** will probably filter that too and remove % from your rating for using it.
Old May 9, 2002 | 12:58 PM
AssPenny's Avatar
If I recall correctly...
You can always make this...
Craig - Who hopes to start selling these one day
Old May 9, 2002 | 01:15 PM
Black R's Avatar
25 Year Member
Default Re: TEST PIPE and NO CEL !!!!!!!!!!!!!!!!!!!! (AssPenny)
Got a printable version?
I could build these into my o2 sensor extenders.....
Old May 9, 2002 | 01:45 PM
comptechgsr2000
Guest
Posts: n/a
You don't even need to goto Radio shack, the way I did it.
Old May 9, 2002 | 01:50 PM
comptechgsr2000
Guest
Posts: n/a
What is the % rating anyways? I have 100% what does that mean?
Old May 9, 2002 | 01:52 PM
BryanSprinkel's Avatar
I have a God Speed test pipe.
Old May 9, 2002 | 02:20 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: TEST PIPE and NO CEL !!!!!!!!!!!!!!!!!!!! (BryanSprinkel)
I had one before and the cat material broke after a month. This caused the cel light to come on. Plus the test pipe was too long which made the exhaust get pushed out. The o2 barely fit.
GODSPEED = CRAP!!!!!!!!!!!
Old May 9, 2002 | 02:24 PM
b00st-0wnz's Avatar
Default Re: TEST PIPE and NO CEL !!!!!!!!!!!!!!!!!!!! (TEXAS TYPE-R)
hahaha yes another member
<<<<<waiting for DAVE to respond
I agree on godspeed. see sig.
AssPenny's Avatar
Dave went home
http://www.dan-sucks.com
Old May 9, 2002 | 02:36 PM
comptechgsr2000
Guest
Posts: n/a
Oh and I also wanted to add that the car is still quiet. Thanks to my RSR exhaust And thank you to SMSP for making the test pipe!!!!!
HERE IS DAN GETTING BEAT UP FOR HIS CRAPPY TEST PIPES!
[Modified by comptechgsr2000, 4:29 PM 5/9/2002]
Old Jun 15, 2002 | 11:33 PM
souk's Avatar
I assume this is an Integra o2. Will this work on 99+ civic o2? And civic o2 has two black, one green, and one white wire. Can you tell me please what each wire is on the pic (above) or even better yet can you please tell what to do for 99+ civic o2(if possible).
thank you in advance
Old Jun 16, 2002 | 02:46 AM
CivicEK.PDX's Avatar
Default Re: TEST PIPE and NO CEL !!!!!!!!!!!!!!!!!!!! (souk)
i just zip yied it to the shift linkage......no problems here
Old Jun 16, 2002 | 06:45 AM
Warren's Avatar
Wrong-Way Wang
Yo Craig, someone's already selling those. I think he's asking like $40 each. He's been selling through one of the other boards, I forgot which, and a few online retailers.
Warren
Old Jun 16, 2002 | 07:11 AM
sackdz's Avatar
Default Re: TEST PIPE and NO CEL !!!!!!!!!!!!!!!!!!!! (Warren)
I my Godspeed testpipe.
kevinm1981
Oct 7, 2009 02:58 PM
IntegraCF21
Sep 24, 2005 04:42 AM
TURBOED-TEG
Jun 24, 2002 09:19 AM
comptechgsr2000
May 9, 2002 07:36 PM
Ri5e
Aug 14, 2001 03:45 PM
