96-98 cupholder in 2000 si
I bought a 96 civic cupholder along with the part for the radio,so i can relocated my radio down there but when i put my radio in ,it seems to just hang in an angle.Is there something that is supposed to be in there that supports the radio up?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
As long as I dont have to take out any more Metal Gears
maybe the metal sleeve that comes with the radio will hold it up, otherwise just get a piece of metal and make your own bracket
metal side brackets that hold a deck (honda part, search http://www.slhonda.com under parts)
or
metal sleeve (universal), as suggested above
or
my JVC cd player didnt fit with the bracket on, but without the bracket it fitted perfect. i also screwed it in from the sides just in case some punk came by and tried to steal it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">That's actually for the separate tape deck, but you could put screws into the side of it.</TD></TR></TABLE>
I realize that
I just used the same bolts and drilled threaded holes in the side of my deck to mount it
I realize that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">
I realize that
same here.....workz perfect but then its a hassle to push the buttonz lol
I realize that
</TD></TR></TABLE>same here.....workz perfect but then its a hassle to push the buttonz lol
numbers 9 and 8
77297-S04-000ZZ
77296-S04-000ZZ
Thats the "correct" way to mount it
You have those...theyre the metal things on the side. They may just be bent outward a little.
(sorry, i forgot to mention that earlier)
you could try metal pipe strapping too...just custom make your own bracket with it
Modified by pdiggitydogg at 10:54 PM 11/27/2006
clayfight3r
18
Jun 23, 2011 05:09 PM
imadigitalgod
Audio / Security / Video
Feb 8, 2008 03:21 AM
ginoboy1978
Mar 31, 2005 04:27 PM
RTW DC2R
Mar 15, 2003 02:28 PM
