Car sounds like it has a gun in it?? IAC ENGINE CODE??
Old Nov 27, 2006 | 03:02 PM
luderollin's Avatar
Default Car sounds like it has a gun in it?? IAC ENGINE CODE??
So i just put a new h23a in my 95 prelude and its spitting out a code 10 - IAC Sensor.. Is this the reason the car sounds like it is popping every couple seconds?... Also it basically runs not so good. Does anyone have any suggestions or anything please?
Old Nov 28, 2006 | 07:09 AM
luderollin's Avatar
Default Re: Car sounds like it has a gun in it?? IAC ENGINE CODE?? (luderollin)
BUMP
Old Nov 28, 2006 | 03:03 PM
luderollin's Avatar
TTT ... no body can help or have any input?
Old Nov 28, 2006 | 03:35 PM
HondaPartsHero's Avatar
Technical Hero
did you do anything timing wise (timing belt, distributor, etc?). If its back firing you probably have a timing issue
Old Nov 28, 2006 | 07:30 PM
luderollin's Avatar
Default Re: Car sounds like it has a gun in it?? IAC ENGINE CODE?? (HondaPartsHero)
when i went to time it i couldnt really see what i was lining it up with the marking in the tranny was faded is there anything i can do to make it easier to time it perfect? like mark with a highlighter somehow?
Old Nov 29, 2006 | 08:19 AM
powerofdreams8's Avatar
yes, a bad/improperly working IAC will cause your car to run rich or lean. Look into your FITV first.
gamajohn
May 13, 2014 01:21 PM
BoostFedDB8
Nov 17, 2007 08:58 PM
88 rex
Dec 14, 2006 11:16 PM
civic_dork
Jul 3, 2005 07:40 AM
