911 Help!! lost key and gotta move car tomorrow!!!!
Old Nov 27, 2006 | 02:12 PM
racacura's Avatar
Default 911 Help!! lost key and gotta move car tomorrow!!!!
ive got a 89 crx. i lost the key. is there a way to pull the vin number to get the key made?? is there a way to unlock the steering wheel without the key so i can turn the wheels? i gotta tow it away on a 2 wheel dolly tomorrow. any suggestions would be huge!! the car is in a garage headlights first with the wheels turned so i cant just back it out. thanks
Old Nov 27, 2006 | 02:16 PM
JJ's civic's Avatar
Default Re: 911 Help!! lost key and gotta move car tomorrow!!!! (racacura)
disconnet the steering colum from the rack.
Old Nov 27, 2006 | 02:19 PM
e jay one's Avatar
Default Re: 911 Help!! lost key and gotta move car tomorrow!!!! (joeny12985)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racacura &raquo;</TD></TR><TR><TD CLASS="quote">is there a way to pull the vin number to get the key made??</TD></TR></TABLE>
yes get the vin and go to a honda dealership.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racacura &raquo;</TD></TR><TR><TD CLASS="quote">is there a way to unlock the steering wheel without the key so i can turn the wheels? </TD></TR></TABLE>
do like joeny said or break the ignition lock.
Old Nov 27, 2006 | 02:29 PM
Donkey85's Avatar
Default Re: 911 Help!! lost key and gotta move car tomorrow!!!! (e jay one)
if you go to honda with the vin and a copy of the reg to proof you own the car then they can make you a key.
Old Nov 27, 2006 | 02:37 PM
TypeRobert's Avatar
Default Re: 911 Help!! lost key and gotta move car tomorrow!!!! (Donkey85)
we do lots of things to our honda you sure you have the original key cylinder in there?
Old Nov 27, 2006 | 02:42 PM
racacura's Avatar
ok, so if i got the title for the car i can go to the dealership and they can 'make' me a key on the spot? or do they give me sum kind of code that i take to a locksmith? also is there a way to disconnect instead of break the steering rack?
Old Nov 27, 2006 | 02:43 PM
Donkey85's Avatar
you go there and they make it on the spot
Old Nov 27, 2006 | 02:46 PM
Freon's Avatar
yes they will make you a key on the spot if you take proof that you own the car.
Old Nov 27, 2006 | 03:26 PM
Crx Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racacura &raquo;</TD></TR><TR><TD CLASS="quote"> also is there a way to disconnect instead of break the steering rack?</TD></TR></TABLE>
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joeny12985 &raquo;</TD></TR><TR><TD CLASS="quote">disconnect the steering column from the rack. </TD></TR></TABLE>
just unbolt the u-joint at the bottom of the column
Old Nov 27, 2006 | 06:34 PM
racacura's Avatar
Default Re: 911 Help!! lost key and gotta move car tomorrow!!!! (Freon)
thanks guys...H-T ftw!
Old Nov 27, 2006 | 06:52 PM
crazykamper's Avatar
its a 10mm bolt on the bottom of steering rack, i just had to undue mine when i swapped out my front sub frame...... then the steering rack is held up by 4 bolts, think its 12mm.....cant remember for sure...
Old Nov 28, 2006 | 02:44 AM
JJ's civic's Avatar
Default Re: (crazykamper)
don't take the rack off just undo the 10mm bolt under the dash and then you can push and pull the tires where you want and push the car.
Old Nov 28, 2006 | 04:47 AM
HT Chaplain's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donkey85 &raquo;</TD></TR><TR><TD CLASS="quote">if you go to honda with the vin and a copy of the reg to proof you own the car then they can make you a key.</TD></TR></TABLE>
you can do the same thing with a locksmith
ck123
11
Jun 7, 2006 12:37 PM
Koyoloeor
Mar 5, 2005 03:45 PM
c1civic
30
May 25, 2004 06:56 AM
TheSSG
Apr 22, 2004 08:19 AM
daddymaxx
Feb 9, 2004 09:19 AM
