911 Help!! lost key and gotta move car tomorrow!!!!
ive got a 89 crx. i lost the key. is there a way to pull the vin number to get the key made?? is there a way to unlock the steering wheel without the key so i can turn the wheels? i gotta tow it away on a 2 wheel dolly tomorrow. any suggestions would be huge!! the car is in a garage headlights first with the wheels turned so i cant just back it out. thanks
Re: 911 Help!! lost key and gotta move car tomorrow!!!! (joeny12985)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racacura »</TD></TR><TR><TD CLASS="quote">is there a way to pull the vin number to get the key made??</TD></TR></TABLE>
yes get the vin and go to a honda dealership.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racacura »</TD></TR><TR><TD CLASS="quote">is there a way to unlock the steering wheel without the key so i can turn the wheels? </TD></TR></TABLE>
do like joeny said or break the ignition lock.
Re: 911 Help!! lost key and gotta move car tomorrow!!!! (e jay one)
if you go to honda with the vin and a copy of the reg to proof you own the car then they can make you a key.
Re: 911 Help!! lost key and gotta move car tomorrow!!!! (Donkey85)
we do lots of things to our honda you sure you have the original key cylinder in there?
ok, so if i got the title for the car i can go to the dealership and they can 'make' me a key on the spot? or do they give me sum kind of code that i take to a locksmith? also is there a way to disconnect instead of break the steering rack?
1 Post
Re: 911 Help!! lost key and gotta move car tomorrow!!!! (racacura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racacura »</TD></TR><TR><TD CLASS="quote"> also is there a way to disconnect instead of break the steering rack?</TD></TR></TABLE>
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joeny12985 »</TD></TR><TR><TD CLASS="quote">disconnect the steering column from the rack. </TD></TR></TABLE>
just unbolt the u-joint at the bottom of the column
yes
its a 10mm bolt on the bottom of steering rack, i just had to undue mine when i swapped out my front sub frame...... then the steering rack is held up by 4 bolts, think its 12mm.....cant remember for sure...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donkey85 »</TD></TR><TR><TD CLASS="quote">if you go to honda with the vin and a copy of the reg to proof you own the car then they can make you a key.</TD></TR></TABLE>
you can do the same thing with a locksmith
ck123
11
06-07-2006 12:37 PM
c1civic
30
05-25-2004 06:56 AM
daddymaxx
02-09-2004 09:19 AM
