MSD quality strikes again.............
I have been having an ongoing problem that pops up from time to time. Well my car would randomly jsut turn its self off while just driving down the road. This started in the summer. Well I checked my main relay, all connections were good no dry sockets or anything. So I traced the path of the power and removed my car alarm, I thought the alarm was going out and just randomly disabled the car. Well I did that and everything was fine untill this morning. Driving to work my car dies, no check engine lights nothing. So i costed off the side of the road. jumped out and checked everything, looked at my batters and there was a little build up on the post but nothing bad so i then though about main relay again. I was ble to sart the car and drive for 15-30 sec then bam it turns off again. SO not i am like fudge it, Call AAA and then call my work and tell them i can;t make it today. Once i get home from hanging out with the redneck AAA guy I source a new main relay from honda. I go get one and then also stop and pick up a new battery for the car, get home and install the battery and it turns over with a qucikness and fires up. Then after about a min it turns itself off with no checkengine lights. So I then put in the new relay. Fires right up idles for 10 min, so i was like problem solved. Put car into gear and then it dies. But this time with a checkengine light. Code 15 --Ignition Output Signal missing or defective ignition output signal. At this point i an grabing the gas can and a lighter.
I pull of MSD dizzy and check that out, looks to be in good shape, then I check the ignition driver....... and here is what I saw..........
not only has the epoxy let moisture into the ingitor on the top left side there is a freaken hair under all the epoxy on the right side.. sitting on top of the R039 chips
Modified by DrVtec99 at 2:03 PM 11/27/2006
At first when I was reading, I was saying to myself...well it could be a fluke, things happen that would explain the moisture. However when I read there was a hair under the epoxy, that didn't fly. You can't explain that...that's plain and simple installation defectiveness. You should definitely connect MSD about that, I would find it hard to believe they could deny that.
Good luck.
Good luck.
Ya hurd good and bad things about MSD myself, sucks to see what happen to you. And I throught that the full MSD dizzy was top notch, I guess not.
yea, can't forget about the dizzy falling apart two months ago
https://honda-tech.com/zerothre...ge=11
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that one doood »</TD></TR><TR><TD CLASS="quote">which is why i stick with oem</TD></TR></TABLE>
too bad oem is garbage too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">
hey it does the job for me
</TD></TR></TABLE>hey it does the job for me
hey it does the job for me</TD></TR></TABLE>
yeah, it works till you want an accurate timing signal going to your ecu
Can you elaborate some more? What is the best setup then?
</TD></TR></TABLE>Can you elaborate some more? What is the best setup then?
Check out the thread about the new MSD dizzy if you want some good tech info about the crappy OEM cam/crank signals.
https://honda-tech.com/zerothread?id=1585765
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr »</TD></TR><TR><TD CLASS="quote">OEM>MSD crap
If you keep the heat off the OEM dizzy, it's 100% perfect.</TD></TR></TABLE>
Dry ice?
lol
I had iginition problems, removed the CD box and it all went away. I plan on M&W in the spring after spending $300 on towing because the ignitor blew.
By the way, the hair is great!
Dry ice?
lolI had iginition problems, removed the CD box and it all went away. I plan on M&W in the spring after spending $300 on towing because the ignitor blew.
It is an encapuslating epoxy..... you pour it in while the piece is upside down, it activates with oxygen, it hardens and that's it.
Looks like they didn't let it fully cure and or the epoxy does not shrink and swell like the plastic does and it seperated on the edges.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade »</TD></TR><TR><TD CLASS="quote">jnk</TD></TR></TABLE>
So is Autronic EMS..... but you rocked it.
Why don't you like it so high one?
