Making hommade ground kit... Suggestions?
I have some 4 guage wire for the kit... thinking I would rather have 8 guage
Looking for several of these:
Or a few of these, depending on price:
And two of these:
Any ideas where I can get any or all of this stuff cheap... and all in the same color (for wires/insulation)? I looked around on e-bay and whatnot, but I don't know the actual names of these items.
Any input is appreciated.
Modified by Wilky at 9:51 PM 11/27/2006
And two of these:
go to ur local circuit city roadshop.. and trust me.. go with 4-gauge or larger. i work in circuit city's roadshop and i did 4-gauge grounds through out the engine bay and one 0-gauge for the negative battery terminal.
Circuit City, for whatever reason, only sells cable in kits. I used to work there as well, ironically. Just went there searching the other day. Their terminals are also very expensive compared to the little bit I can find online (ebay).
Thanks for the help, though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Budget EJ »</TD></TR><TR><TD CLASS="quote">what exactly does a grounding kit do for your car? I've heard of it but never got a real good explanation
better grounds than old stock rusty ones. try unhooking all your grounds then start the car then youll realize how important all the little grounds are then why not add more.
</TD></TR></TABLE>better grounds than old stock rusty ones. try unhooking all your grounds then start the car then youll realize how important all the little grounds are then why not add more.
http://www.partsexpress.com has a lot of what you need for relatively cheap, power cable all gauges, and all sorts of inexpensive connectors.
your best bet would be to go to a place where they sell sound systems. im sure they have an abundance of those parts there. i know the local one here does.
Ok Home depot is a bad idea because they don't sell the right kind of wire. They have stuff for houses not cars.
Go to http://www.sounddomain.com. Everything you have listed there is for car audio stuff. I upgraded several of my grounds when I did my sub and amp install. You will need to soder (sp?) the ring terminals onto the wire so you get a good connection.
Here are links for the things you have pictured there.
Wire (all sizes colors and sold by the foot)
http://www.cardomain.com/shop/...&y=14
Wire Terminals
http://www.cardomain.com/shopl...inals
Battery Terminals
http://www.cardomain.com/shop/...&y=23
This site has a TON of stuff for just about any install you can think off. Just look through and be careful becuase you can drop alot of money. The nice thing is their shipping is really cheap.
Hope that helps alittle.
Wire Terminals
Battery Terminals
Thanks for all the info, bro. I will definitely be soldering the wires to the terminals to ensure a strong/efficient connection. Good info.
Now, if I can just find all the grounding points....
My local Circuit City, however, does not sell cable by the foot (at least audio or power cable). They sell kits to go with installs. Plus all their terminals and whatnot are ridiculously expensive, at least for my HMT blood.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 »</TD></TR><TR><TD CLASS="quote">http://www.partsexpress.com has a lot of what you need for relatively cheap, power cable all gauges, and all sorts of inexpensive connectors.</TD></TR></TABLE>
i've got to agree with him they've never steered me wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboekcivic »</TD></TR><TR><TD CLASS="quote">look for a local stereo shop anywhere they have everything you need. </TD></TR></TABLE>
x2
x2
your best bet would be a stereo shop. I just recently did mine too and went to a stereo shop to get my stuff. I told them the length I needed and they gave me whatever length I needed and how many wires I needed. They also gave me copper ends too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic »</TD></TR><TR><TD CLASS="quote">would it better to use soldered, or crimp connectors? </TD></TR></TABLE>
crimp the connectors...then heat shrink it...
crimp solder and heat shrink.
but you'll need a huge iron to solder 1/0 gauge, like 100W perhaps. Soldering after crimping prevents a 'cold' crimp/connection, more of the strands will be actually 'touching' each other if soldered. tinnined ends is not really the same, its still only cold crimped to the connector.
if u have a good crimper u won't need to solder any cable to ur terminal. i've installed audio systems on hundreds.. probably thousands of cars now.. and if u know how to crimp.. it'll work fine. my assistant manager made these special crimpers for 0-gauge. he took a chain cutter and welded some stuff to it.. then grinded it so it became a big *** crimper. aint **** coming loose from that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance »</TD></TR><TR><TD CLASS="quote">if u have a good crimper u won't need to solder any cable to ur terminal. i've installed audio systems on hundreds.. probably thousands of cars now.. and if u know how to crimp.. it'll work fine. my assistant manager made these special crimpers for 0-gauge. he took a chain cutter and welded some stuff to it.. then grinded it so it became a big *** crimper. aint **** coming loose from that.</TD></TR></TABLE>
I don't doubt a good wire crimper's ability to have a solid hold on wire; a soldered and crimped connection should have less resistance than the same crimp unsoldered.
