wont start trouble ls/vtec
Old Nov 27, 2006 | 11:17 AM
ef dino's Avatar
Default wont start trouble ls/vtec
i gotta ls/vtec, i dropped it in a civic and it wont crank at all. it just feels like the battery is dead or something. but i changed the battery and it still just wont start. the lights and everything go on. but when i turn the key, itll do the same thing as if your foot wasnt on the clutch. The only plug that i havent plugged in is one right above the alternater, not on the alternator. its like 2 inches above it and its like on the block. does that have anything to do with the starter?
Old Nov 27, 2006 | 11:18 AM
ef dino's Avatar
Default Re: wont start trouble ls/vtec (xskiesgoblackx)
edit: ive seen the motor run fine before it was out of the car.
Old Nov 28, 2006 | 06:54 AM
Fezzie's Avatar
plug in everything first, then check all fuses, make sure fuel pump works, check wires coming from starter
Old Nov 28, 2006 | 07:38 AM
DRAG_WORKX's Avatar
you have to check if you ground the chasis, or else it wont start
speedfreek128
Honda S2000
Mar 13, 2015 07:49 AM
FLA$HY_5SiX2
Nov 8, 2011 02:57 AM
zacatkings
27
Mar 22, 2006 05:26 AM
Ph0eNix
Dec 15, 2005 11:58 AM
deftones0817
Jul 14, 2005 08:17 AM
