Going to flush my brake sys, should I use a 'better' fluid than OEM Honda?
Old May 9, 2002 | 12:11 PM
ILUVTEC's Avatar
Default Going to flush my brake sys, should I use a 'better' fluid than OEM Honda?
Just replacing my front rotors, and getting better brakes pads all around, and I was planning on sticking with Honda's brake fluid, but should I 'upgrade' to a better fluid while I'm at it? This will only be for the street with maybe an autocross or two. What do you suggest? Oh, and I have a 99 GSR. Thanks.
[Modified by ILUVTEC, 9:12 PM 5/9/2002]
Old May 9, 2002 | 12:35 PM
ALF's Avatar
ALF
Default Re: Going to flush my brake sys, should I use a 'better' fluid than OEM Honda? (ILUVTEC)
Valvoline SynPower. Readily available at any car parts place. It will do very well for street and occasional Auto-X.
Old May 9, 2002 | 01:43 PM
Sonic's Avatar
Default Re: Going to flush my brake sys, should I use a 'better' fluid than OEM Honda? (ALF)
I agree with what ALF said...if you think you might ever do a track day, spend the extra few dollars and use Motul 600 or ATE Super Blue.
Old May 9, 2002 | 01:50 PM
SamC's Avatar
Default Re: Going to flush my brake sys, should I use a 'better' fluid than OEM Honda? (Sonic)
how often do you flush the brake system?
Old May 9, 2002 | 02:08 PM
Gennady's Avatar
New User
Default Re: Going to flush my brake sys, should I use a 'better' fluid than OEM Honda? (SamC)
Depends on how often you take it to the track.
[Modified by Wont be beat, 6:09 PM 5/9/2002]
Old May 9, 2002 | 02:52 PM
krshultz's Avatar
Sounds to me like you should use the Valvoline stuff the others have suggested. Easy to find, cheap, and doesn't suck up water like Motul.
--Karl, who uses Motul 600 in his race car, and Valvoline in everything else
Old May 12, 2002 | 11:01 AM
90IntegraXSi's Avatar
ate super blue is good stuff. you can pick up some for around 12.00-15.00 for a quart or however it comes
Old May 12, 2002 | 12:53 PM
MrFatBooty's Avatar
Default Re: Going to flush my brake sys, should I use a 'better' fluid than OEM Honda? (90IntegraXSi)
Just random info, Ate is pronounced "AH-tay". It's like Swedish or something.
Old May 12, 2002 | 04:22 PM
Bror Jace's Avatar
I use the Valvoline Synpower fluid (I used to use Castrol LMA) and have had no problems with it ... but then my car has no ABS. I last swapped my fluid out in 1998 and it is still not dark in my resevoir. I might change it out again this year ... not sure.
Like it was said before, the racing fluids may deal with heat better, but they don't deal with moisture as well as the more 'streetable' fluids. If you use one, be prepared to drain it more often.
--- Bror Jace
Old May 12, 2002 | 06:22 PM
non-VTEC's Avatar
Default Re: Going to flush my brake sys (Bror Jace)
how did you find the Castrol LMA? good? no good? ok?
Old May 13, 2002 | 04:02 AM
Bror Jace's Avatar
Default Re: Going to flush my brake sys (non-VTEC)
I found Castrol LMA to be fine ... but since they've been screwing around with their Syntec motor oil formulas, I stopped buying anything with their name on it.
--- Bror Jace
Ghetto Civic HX
63
Oct 6, 2005 01:16 PM
Tad
27
Jun 18, 2005 06:18 PM
CivicSiRacer
53
Apr 9, 2002 08:31 PM
C1V1C
24
Apr 3, 2002 08:20 PM
