PLX M300 wideband install on SH
Old Nov 27, 2006 | 08:45 AM
lude98SH's Avatar
Default PLX M300 wideband install on SH
I have seen DIY writeups on this install but the wiring on the SH 02 sensor is different. I havent attempted to install it in a few months so i forget the details but does anyone have a DIY or any info on the install on an SH ?
Old Nov 27, 2006 | 09:03 AM
Hawkze_2.3's Avatar
Default Re: PLX M300 wideband install on SH (lude98SH)
Why not just weld another bung onto your exhaust? That's what I ended up doing and it seems like the easiest way...
Old Nov 27, 2006 | 09:17 AM
lude98SH's Avatar
Default Re: PLX M300 wideband install on SH (Hawkze_2.3)
That is what I am begining to lean towards. Would prolly be alot simplier in the end.
Old Nov 27, 2006 | 11:46 AM
98vtec's Avatar
moderator emeritus
why are you trying to wire it to the SH 02 sensor?
Old Nov 27, 2006 | 12:27 PM
lude98SH's Avatar
Default Re: PLX M300 wideband install on SH (B.Rabbit)
No an SH o2 sensor is different than the base. I dont know if its just longer or something but its different and all the writeups Ive seen the wiring is different colors and Im not sure how to hook it up. But like Hawkze said I will prolly end up just getting another o2 bung welded in
Old Nov 27, 2006 | 12:36 PM
mgags7's Avatar
Yeah just weld another bung....unless you plan on using that whole self-tuning thing that hondata has, there is no reason to do all the work to get it to work the other way.....
Old Nov 27, 2006 | 03:59 PM
SteveoBA8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Why not just weld another bung onto your exhaust? That's what I ended up doing and it seems like the easiest way...</TD></TR></TABLE> That's the route im going. If you want to put the wideband in place of the factory narrowband then go to PLX's website, it'll tell you how to wire it.
Old Nov 27, 2006 | 04:14 PM
92bluepreludeSi's Avatar
Default Re: PLX M300 wideband install on SH (SteveoBA8)
isnt there like two wires you have to wire into the ecu wiring harness? the m300 should have come with the wideband sensor, harness to connect sensor to plx gauge and a narrowband, wideband output, ground and power wire. Just wire the narrow band and ground into the ecu harness and find an ignition power wire to tap into to power the gauge. PLX has a writeup and so does the instruction manual that comes with it. and if you dont know what pins the narrowband and ground go to the prelude FAQ, should be some ecu pinouts in there somewhere.
94typeR
Apr 9, 2007 01:55 PM
lude98SH
Jun 29, 2006 07:54 PM
SantaCruz92Si
Jan 27, 2005 08:45 PM
