Oil pressure switch port turbo safe?
Old Nov 27, 2006 | 05:21 AM
Quade's Avatar
Default Oil port at pressure switch turbo safe?
I've done some research and it seems that the oil port at the pressure sending unit is the perfect place to tap for the turbo oil feed but is it really? Is there filtered oil at this port? In other words is this port before or after the filter. I want to know because I would like filtered oil going to the turbo. It is also said that oil pressure at the Vtec solenoid port (filtered oil) fluctuates with vtec which isn't good for the turbo seals either. Anyone know for sure?
Old Nov 27, 2006 | 05:30 AM
mgags7's Avatar
If you tap into the oil feed for vtec, of course the pressure is going to go down when vtec hits....
Old Nov 27, 2006 | 05:46 AM
Finest's Avatar
Default Re: Oil port at pressure switch turbo safe? (Quade)
If you're that worried, run the GE oil filter sandwich then use the ports for the oil feed. It's filtered from there.
jrs2ksi
Nov 21, 2006 03:19 PM
99Sivic
May 7, 2006 01:39 PM
NtenseMotorsports
Jan 15, 2004 07:45 PM
austrian type-R
Feb 21, 2002 11:35 PM
