Valve adjustment tip
Old Nov 27, 2006 | 02:04 AM
clayne's Avatar
Default Valve adjustment tip
Just wanted to let everyone know that those gear drive kits (which are also quite useful in their own right due to the low profile of the sockets) also double as a convenient lock-nut tool as the gear drive ratchets themselves grip the sockets on the outside - leaving a nice large inner accessible hole in each socket. Perfect to place a screw driver down while tightening the lock nut. Used one tonight to adjust some valves.
http://www.gearwrench.com/ratc...x.jsp
Old Dec 1, 2006 | 07:39 AM
EnjoyTheRideDC2's Avatar
Default Re: Valve adjustment tip (clayne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clayne &raquo;</TD></TR><TR><TD CLASS="quote">Just wanted to let everyone know that those gear drive kits (which are also quite useful in their own right due to the low profile of the sockets) also double as a convenient lock-nut tool as the gear drive ratchets themselves grip the sockets on the outside - leaving a nice large inner accessible hole in each socket. Perfect to place a screw driver down while tightening the lock nut. Used one tonight to adjust some valves.
http://www.gearwrench.com/ratc...x.jsp</TD></TR></TABLE>
I find this easier to use in comparison to the Snap On Valve Adjustment Tool. Been using this method for a couple years now. Good tip!
Old Dec 1, 2006 | 10:08 AM
98vtec's Avatar
moderator emeritus
Default Re: Valve adjustment tip (EnjoyTheRideDC2)
powerbuilt valve lash tool
20 bux on ebay
Old Dec 1, 2006 | 08:44 PM
wickedEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
I find this easier to use in comparison to the Snap On Valve Adjustment Tool. Been using this method for a couple years now. Good tip! </TD></TR></TABLE>
Old Dec 2, 2006 | 07:33 AM
Default Re: Valve adjustment tip (B.Rabbit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B.Rabbit &raquo;</TD></TR><TR><TD CLASS="quote">powerbuilt valve lash tool
20 bux on ebay </TD></TR></TABLE>
Very true, but there's still a difference in quality between the Snap on tool and the Powerbuilt version. I've known some people to actually round out the adjustment nut from use of the powerbuilt tool. It doesn't fit as snug as the snap on version.
But regardless, i'm still with the gearwrench/Flathead method.
092eg6
Transmission & Drivetrain
Dec 15, 2009 07:01 PM
NA JDM GSR
Nov 1, 2006 07:45 PM
gray_civic_coupe
Jan 8, 2006 12:49 PM
Edw-R
Oct 26, 2004 09:34 PM
ferio 95
Feb 14, 2004 11:16 AM
