91 Accord EXR cooling system woes!!
Old Nov 27, 2006 | 01:13 AM
seelyd's Avatar
Default 91 Accord EXR cooling system woes!!
I have a 91 EXR. There seems to be something wrong with the cooling system cause it keeps pusing the coolent into the overflow. It will only push about enough to fill the overflow container and that's it. I thought it might be a bad thermostat but I changed that but it keeps doing it. I know the water pump is good cause I checked it when I recently replaced the crank shaft and pully. Anyone have any ideas cause my brain is getting fried trying to figure this one out!
Old Nov 27, 2006 | 07:57 AM
hondadude's Avatar
Default Re: 91 Accord EXR cooling system woes!! (seelyd)
Any overheat problems? I'd suggest a new radiator cap. I've seen those radiator necks get distorted from overheating, thats why I asked.
Also it could be the radiator is getting plugged up, but you should consider that the coolant expands when hot and will raise the level of the overflow bottle, but with a good rad cap the coolant level in the overflow bottle should drop some when the engine cools off.
Old Nov 27, 2006 | 11:36 PM
seelyd's Avatar
Default Re: 91 Accord EXR cooling system woes!! (hondadude)
No overheating problems yet. It only ever overheated once when I blow the heater hose and lost all the fluid. I'll try the new radiator cap. Thanks!!
Old Dec 1, 2006 | 05:08 PM
birdman123's Avatar
you probably have air in your cooling system. you need to burp it bro. fill it up with water take your radiator cap off cut it on and let it bubble while you slowly add more water. do this until it stops bubbling then cap it and see what happens.
these accords are very tempermental when they have air in the cooling system. if you hasve any qs let me kno
Old Dec 1, 2006 | 09:39 PM
AJ06's Avatar
What ^^^ said and the read cap... Try it see what happens
Gerard Bonnett
Jul 5, 2016 06:58 AM
luvinthelude
Feb 11, 2014 06:17 AM
FordWithAccord
Aug 3, 2011 11:55 PM
whiteboy4life74
Aug 26, 2004 08:07 AM
92VtecTeggy
Jun 20, 2003 08:13 AM
