How do I check bearing clearances without the original rod bearings and mixed up main bearings?
Old Nov 26, 2006 | 10:30 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default How do I check bearing clearances without the original rod bearings and mixed up main bearings?
how do I check my rod bearing clearances if I don't have the original rods and rod bearings for the crank?
and when I had my block re-sleeved, I removed the main bearings without labeling their original location so how do I check my main bearing clearances if I have mixed up the main bearings?
Old Nov 27, 2006 | 03:33 AM
91SiZ6's Avatar
Mic the crank journals, use a dial bore gauge on the large end bores of the rods and main journals (with bolts torqued to spec), and subtract the crank journal from the journal bores. Now add your desired clearance to this and you have the thickness of the bearings you need.
Old Nov 27, 2006 | 11:38 AM
Default Re: (91SiZ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 &raquo;</TD></TR><TR><TD CLASS="quote">Mic the crank journals, use a dial bore gauge on the large end bores of the rods and main journals (with bolts torqued to spec), and subtract the crank journal from the journal bores. Now add your desired clearance to this and you have the thickness of the bearings you need.</TD></TR></TABLE>
when i measure the bores of the rods and main journals, i measure them without bearings on them?
and what if i want to double check using plastigauge can i utilize any of the bearings?
Old Nov 27, 2006 | 11:51 AM
RStoR's Avatar
Default Re: (JDM turbo DC)
yes, without bearings in them.
measure mains I.D.
measure main journals O.D.
measure rod B.E. I.D.
measure rod journals O.D.
I.D. - O.D. - clearance spec you want = bearing thickness you order.
you can use plastigauge to double check the clearance of the bearings you order.
Old Nov 27, 2006 | 11:57 AM
Default Re: (RStoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RStoR &raquo;</TD></TR><TR><TD CLASS="quote">yes, without bearings in them.
measure mains I.D.
you can use plastigauge to double check the clearance of the bearings you order. </TD></TR></TABLE>
what brand and what kind of mic should i get without spending too much?
Old Nov 27, 2006 | 04:21 PM
more input please
Old Nov 28, 2006 | 07:40 AM
DRAG_WORKX's Avatar
mic the crank
Old Nov 28, 2006 | 12:37 PM
91SiZ6's Avatar
Unless you're planning on doing a lot where you would need a mic, I'd probably take it to the maching shop and have them do it for you. It shouldn't cost very much.
jakscivic
Feb 21, 2013 08:27 AM
r1de4life
Oct 23, 2007 06:40 PM
crxhf19
May 21, 2005 04:56 PM
rocket_R
May 13, 2005 09:19 AM
Mouchyn
May 15, 2004 03:29 PM
