IAC ERROR? B18c Hondata s300
Old Nov 26, 2006 | 10:06 PM
delsolitude's Avatar
Default IAC ERROR? B18c Hondata s300
ok i started with a "B18c obd2" imported jdm into my delsol
and i bought a obd2a to obd1 converter
and i got the P72 obd1 ecu....
and i socketed it with a s300
and after some finicking with it... i have gotten it to work great.
datalogs and everything... but the car idles at 621 rpm and the original ecu idles at 1000
(621 if im gentle, will just plain die if i let go of gas)
I also noticed i have an iac error. is the ecu supposed ot have this error after being s300'ed? i clicked the "disable iac error" button in hondata so atleast i dont have a check engine light. but i dont like the fact its there. would the rest of hondata work and just not that 1 thing? doesnt make sence.
i can upload and download from the ecu perfectly. and as i said datalogging runs great.
IAC a big deal if i cant fix it? intake air control doesnt sound TOO bad to not have?
or is that related to switching from obd2 to obd1?
so many things being changed in this 1 upgrade. not sure if its even a problem.
i mean i can fix the idle with the physical idle control under the hood
plz any help is greatly appreciated. not going to drive on the new ecu till i know IAC isnt going to ruin my freshly imported engine.
Old Nov 27, 2006 | 08:01 PM
Default Re: IAC ERROR? B18c Hondata s300 (delsolitude)
no one knows if IAC error is important?
Old Dec 5, 2006 | 07:41 AM
skratch1200s's Avatar
bump because a fellow ht user needs help . .. wish i knew more, but hopefully someone can grant some insight
Old Dec 9, 2006 | 07:42 PM
Default Re: (skratch1200s)
turns out the ecu i bought off the marketplace was defective.
stupid lemons on the market place grrr
Old Dec 10, 2006 | 05:52 PM
havok hybrid's Avatar
Default Re: (delsolitude)
with a hondata s300 you can or could have checked the box. Disable IAC .. Located under the IAC settings.
Irish Racer
Engine Management and Tuning
May 23, 2012 08:55 AM
connor53
Oct 5, 2008 02:15 PM
01_ITR
Jul 8, 2008 04:40 PM
debogsr
Sep 24, 2005 10:49 PM
eeyore357
10
Oct 21, 2004 07:38 AM
