Cam gear settings with S2S1's and 11.4:1 c/r?
Old Nov 26, 2006 | 09:21 PM
MotorSpecies ver1.6's Avatar
From: MoonSHINE Metropolis, .FL. Run Free, North America
Default Cam gear settings with S2S1's and 11.4:1 c/r?
Hello, Im curious as to what possible maxiumum settings on adj. cam gears you can go on this setup(s2s1,b16a w/Pct's.. 11.4:1)without clearance issues.Also considering, max. setting in various directions(ex. int/exh,adv/rtd ...visversa)
Thanks.
Old Nov 26, 2006 | 09:23 PM
Suck my DX's Avatar
Default Re: Cam gear settings with S2S1's and 11.4:1 c/r? (xtrada ver1.6)
clay the motor...its the only accurate way too find out
Old Nov 26, 2006 | 09:28 PM
Default Re: Cam gear settings with S2S1's and 11.4:1 c/r? (Suck my DX)
True,true.....any educated guesses though?
Old Nov 26, 2006 | 09:29 PM
Suck my DX's Avatar
i couldnt tell you...thats not something i would leave to guessing either
Old Nov 26, 2006 | 09:38 PM
LOL,.....True,true.
Thank you
Old Nov 26, 2006 | 10:22 PM
MikeSarr_GSR's Avatar
those cams have enough overlap that you could get something wrong.
you might want to advance the exhaust and intake a degree and
see where that leaves you. maybe +2/10in, +1/10ex to get the lobe
centers in there a bit quicker. those cams have good bark to them.
they tend to go flat around 6800rpm for a couple hundred rpm then
wake up again. you might sacrifice a couple peak whp this way but
your driving area will be a bit more beefy I will assume
you know that separating the cam angles more is more risky with
a bigger cam. moving them forward or retard in the same amount
is fine up to a certain point. moving both forward and sneaking one
out one more degree I think is a safe place to start. it also depends
on if you have a milled head or thinner head gasket, keep that in
mind good luck. standalone tuning with stock cam timing
is better than a million adjustments and trusting the butt dyno.
Old May 11, 2007 | 09:57 PM
Default Re: Cam gear settings with S2S1's and 11.4:1 c/r? (MikeSarr_GSR)
tru truu. The pistons are pct's btw(3lyr H. Gskt/no mill). Is 11.4:1 correct ?
Old May 11, 2007 | 10:02 PM
-Championship-'s Avatar
76.169.175.137
Default Re: Cam gear settings with S2S1's and 11.4:1 c/r? (MotorSpecies ver1.6)
11.9 is what zeal compression calculator says
Old May 11, 2007 | 10:24 PM
Default Re: Cam gear settings with S2S1's and 11.4:1 c/r? (-Championship-)
Hmm Ive been getting answers between 11.4ish-12.0ish.Is v2v or p2v gonna be an issue if I advance them both a degree....
Old Nov 29, 2007 | 04:21 PM
LDS's Avatar
LDS
I want to hear more.
Old Nov 29, 2007 | 04:26 PM
LDS's Avatar
LDS
Default Re: (LDS)
I just realized how old this post was LOL.
DrGrEeNtHuMb
Jul 29, 2009 01:08 PM
alterdcreations
Jan 24, 2007 11:45 AM
urgonnalearn2
Nov 8, 2004 12:32 PM
skunk2gsr
Apr 19, 2004 08:16 AM
