which clutch
i'm putting a h23 in and i figured i should do the clutch. ebay has clutches for 100 bucks for a 4th gen stage one. and with the flywheel for 200. should get a name brand like exedy or are these fine. let me know
thanks alot
thanks alot
#1 - those are not stage 1. They are OEM replacement.
#2 - Theyr are 100% full replicas of exedy on ebay as well. same logo, box, everything .. except its garbage. Also clutch pressure plates can explode if not designed properly. Most clutch instructions warn of possible injury or fatality if the clutch pressure plate blows (think connecting rod shooting out the block and threw your head).
this is the one i just bought. seller seems pretty reputable, with 11k+ sales and 99.9% positive. got the clutch in 4 days. this was recommended to me a few months back by a bunch of guys on here, its Exedy brand but its the exact same as an OEM. its what you need, nothing more.
ebay clutch
ebay clutch
I got that clutch kit and it works great with my XTD 11lb flywheel. The only thing that really sucks is the throwout bearing was no good and now my car makes noise when the clutch is not engaged. So i would get OEM Honda TB if I did it again becasue it is pretty cheap.
so im using a h23 with headers, cold air, full exhuast and high flow cat, and cams will i need any more than that exedy clutch. my friend has a stage 3 and a it grabs so nice when he shifts. would that do that or should i get a stage 2 or 3
I just bought a whole new clutch KIT!!!!h23a $under $200! flywheel, clutch, plate, throw out , etc. complete.
All exedy and daiken
Ezclutch Is the seller. 99.9 feedback. Licensed Distributor! so it's Reputable.
GOOD deal! I think i paid $193 !!!! complete!
Daiken Flywheel, Exedy Clutch, Pressure plate, alignment tool, throw out
pinks11
Mar 27, 2010 05:58 PM
