what would be a good vtec crossover point B16b with a GSR head ???
Old Nov 26, 2006 | 08:48 PM
eg4life1202's Avatar
Default what would be a good vtec crossover point B16b with a GSR head ???
my setup is a stock B16b block mated with a Gsr head
i have a 68 mm throttlebody sk2 pro manifold dc 421 headers and 2 1/4 exaust
trying to save up for a good tune but until then ...
i have a chipped ecu running mild program
off hand does anyone have a good vtec crossover point ??
currently it crosses at 5300 rpm but i think it would be stronger if it was around 4800 or 4900
any input would be helpful thanks
Old Nov 27, 2006 | 10:57 AM
blinx9900's Avatar
Default Re: what would be a good vtec crossover point B16b with a GSR head ??? (eg4life1202)
i wish it was that easy... i really think it varies too much to be able to tell you but if you want my .02 its this: my b16b is similar and crosses over at 6k its perfect... i personally dont think you have enough done to warrent a change in vtec crossover... keep it at 6k thats the stock cross over according to my pos factory tach and ctr ecu...
edit: oops i didnt realise you porably have gsr cams, i withdraw my comment about the 6k crossover...
Modified by blinx9900 at 3:17 PM 11/27/2006
Old Nov 27, 2006 | 12:52 PM
doood's Avatar
been there done that
does the head still have the stock cams and intake manifold?
Old Nov 27, 2006 | 02:58 PM
allnaturalb16's Avatar
Default Re: what would be a good vtec crossover point B16b with a GSR head ??? (that one doood)
5300 is good....i have the same setup with a lil bit more on it but same head setup and tuned ecu vtec is at 5300
Old Nov 27, 2006 | 03:27 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: what would be a good vtec crossover point B16b with a GSR head ??? (allnaturalb16)
if they are gsr cams then 4700ish
but
<FONT COLOR="blue">GET IT TUNED</FONT>
Old Nov 27, 2006 | 10:34 PM
Default Re: what would be a good vtec crossover point B16b with a GSR head ??? (WHITFIELD-TUNED)
yea they are gsr cams
i tend to feel a dip in power from 5300 to about 5700 after vtec then it will start to pull again
if i were to lower the vtec to lets say 5000 with another chip would it start to pull sooner like ???
i have a buddy that hooks it up with chips
the reason is bacause when i shift from second to third on my gsr transmission it leaves me at about 4500 rpm out of my power band
thanks sorry if i sound like a noob
Old Nov 28, 2006 | 09:15 AM
blinx9900's Avatar
what rpm you shiting at that lands you at 4500? dont forget the factory tach is not accurate so you might think your at 8000 but you could be at 7500, best way to check is hit the revlimiter one time and you'll know how inaccurate yours is, my si cluster for instance shows 9100rpm but im really only at 8600...
josh89
15
Jun 26, 2009 08:36 PM
94gsrvtek19
Sep 28, 2005 05:50 PM
Spectrum24x
Apr 13, 2005 10:43 PM
CRVtec95
Feb 20, 2005 12:29 PM
B18C-RnVA
Dec 22, 2002 01:47 PM
