vtec solenoid question
Old Nov 26, 2006 | 08:01 PM
perseverance's Avatar
Default vtec solenoid question
are vtec solenoids interchangeable? and if so... can u swap d-series solenoid's with b-series solenoid's? and if so will u notice an increase in performance>? thx a lot in advance.
Old Nov 26, 2006 | 08:04 PM
Kamin's Avatar
Default Re: vtec solenoid question (perseverance)
while the outside casings are different they all work the same and interchange.
there is no performance benefit.
Old Nov 26, 2006 | 08:08 PM
egmatt93's Avatar
Default Re: vtec solenoid question (Kamin)
can these solenoids go bad and need to be replaced? and if so would u notice a difference
Old Nov 26, 2006 | 08:14 PM
Kamin's Avatar
Default Re: vtec solenoid question (egmatt89)
of course they can go bad
and it depends on the engine if you will notice a lack of VTEC. something like a HX that has "economy" vtec you will probably never notice.
but on a Z6 or y7 SOHC or any b/h/k yes its noticeable.
Old Nov 26, 2006 | 08:33 PM
dafuzzbudd's Avatar
i think it's either
a) vtec works when it's suppose to
or
b) vtec doesn't work when it's suppose to
any other problem wouldnt have to do with the solenoid
i could always be wrong though
Old Nov 26, 2006 | 10:51 PM
s_18's Avatar
Default Re: vtec solenoid question (dafuzzbudd)
Yeah, there isn't more to it than that. You can't get better vtec or anything from changing solenoids.
So, unless your engine has a problem activating vtec, you should look at other things for performance increases.
Old Nov 27, 2006 | 04:11 AM
k, thx for the info. my friend suggested that i put a b16 vtec solenoid on my d16y8 cause it was kick in harder or something. i wasn't sure so i asked. do vtec solenoid's sound any different? mine is noticeable during crossover but not as noticeable as my friends' prelude. thx
Old Nov 27, 2006 | 08:11 AM
Kamin's Avatar
Default Re: (perseverance)
thats because he has a dual cam vtec. you only have a single. he has vtec on both intake and exhaust while yours is only intake side.
Old Nov 27, 2006 | 08:20 PM
dafuzzbudd's Avatar
Default Re: (Kamin)
vtec is done in your engine your solenoid only detects/starts the transformation
the solenoid pretty much "does" nothing
iCollectStraws
Oct 9, 2020 05:27 PM
h4mza
Feb 22, 2013 10:13 AM
xvracing
May 1, 2004 01:49 PM
LordoftheAccord
Nov 16, 2001 08:38 PM
HorrorDog
Nov 11, 2001 09:32 PM
