project integra
Old Nov 26, 2006 | 07:16 PM
acura9's Avatar
Default project integra
i have a 1991 integra ls i plan to buy the bolt ons tommorw and eventually swap it over to ls/vtec should be done sometime soon also plan on buying hondata in opinion what else should i do engine wise besides nitrious. here is a pic now...
i plan on lowering with new coil overs and springs once i get more money up
inside
Old Nov 26, 2006 | 07:31 PM
mra4886's Avatar
just boost it.
Old Nov 26, 2006 | 07:33 PM
acura9's Avatar
Default Re: (mra4886)
what just boost it as it is now without putting the b16 head in?
forumnoobie's Avatar
Default Re: project integra (acura9)
save that money your going to invest in nitrous and put it towards a turbo or sc imo. looks good
Old Nov 26, 2006 | 07:36 PM
acura9's Avatar
Default Re: project integra (forumnoobie)
haha i accidently put in the wrong thing i don't want to put nitrious in there but ya then just boost it then basiclly??? and if so what kind should i go for i don't want any ebay kits
Old Nov 26, 2006 | 07:44 PM
wadecarter89's Avatar
read up on turbos in the forced induction area, and then decide what turbo you need for your application.
Old Nov 26, 2006 | 07:52 PM
acura9's Avatar
Default Re: (wadecarter89)
will i get like 100000hps to the wheels haha
Old Nov 26, 2006 | 08:10 PM
turbod da's Avatar
Default Re: (acura9)
no youll make 000001 on a good day.......no on a grreeeaaatttttt day!
Old Nov 26, 2006 | 08:11 PM
acura9's Avatar
Default Re: (SNACH)
dang i can't wait to make that much hp
Old Nov 26, 2006 | 08:19 PM
turbod da's Avatar
boost lsvtec!
Old Nov 26, 2006 | 08:23 PM
acura9's Avatar
Default Re: project integra (SNACH)
do u think i can do wheelies when this is all done haha jk but how much hp u think ill be making just with boost and try and get mostly everything else inside the enigine?
Old Nov 26, 2006 | 08:45 PM
turbod da's Avatar
u mean stock internals?
Old Nov 26, 2006 | 09:25 PM
aaronISthrowed's Avatar
Looks good, now all you need is boost.
Old Nov 26, 2006 | 09:30 PM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acura9 &raquo;</TD></TR><TR><TD CLASS="quote">how much hp u think ill be making just with boost and try and get mostly everything else inside the enigine?</TD></TR></TABLE>
After all the research you do, and then eventually get it all done,
The dyno you test the car out on will tell you exactly how much it will make.
But just a Rough number, low-moderate boost on a nicely sized compressor,
and you should make anywhere from 150-250hp.
Old Nov 26, 2006 | 10:30 PM
Ghett0_ed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acura9 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 1991 integra ls i plan to buy the bolt ons tommorw and eventually swap it over to ls/vtec should be done sometime soon also plan on buying hondata in opinion what else should i do engine wise besides nitrious. here is a pic now...
inside</TD></TR></TABLE>
YA!!!!!!!
lol i have that hat!!!!
so bump haha
Old Nov 26, 2006 | 10:37 PM
matt2001teg's Avatar
i plan on lowering with new coil overs and springs once i get more money up</TD></TR></TABLE>
Coilovers and springs....one or the other
Old Nov 26, 2006 | 11:49 PM
mr_hahn73's Avatar
Default Re: project integra (matt2001teg)
to do it right you will have to do a new pump,fpr and injectors with a tune. Might as well just boost it. Been there done that u will be a lot happier with boost!
Old Nov 27, 2006 | 03:36 AM
PrinceAli132's Avatar
First spend your money on getting the car running pefectly. Make sure all the maintenance is up to date. Check all wear items; i.e. bushings, balljoints, tie rods, hoses, etc. Your just going to run into tons of problems in the future if you avoid all this.
Ali
Old Nov 27, 2006 | 09:19 AM
Swiftstar's Avatar
your car looks Great.
Old Nov 27, 2006 | 10:18 AM
93Ls-tegra's Avatar
inside</TD></TR></TABLE> to start what head b16 or b18c1? what bolt on's?and are u gonna run stock internals on nitrous? also which one coilovers or springs cant have both.....?
Old Nov 27, 2006 | 03:08 PM
phayzeone's Avatar
Default Re: project integra (93Ls-tegra)
Old Nov 27, 2006 | 03:35 PM
/\ why ????
Old Nov 27, 2006 | 04:01 PM
MatMattMatthew's Avatar
why ls/vtec? At very least do a b20vtec. You can pick up a B20 block for super cheap, or even a full jdm B20 from Password for 550.
Old Nov 27, 2006 | 04:11 PM
phayzeone's Avatar
Default Re: (MatMattMatthew)
Use the search function...or just look around the site. You will find plenty of info
Old Nov 27, 2006 | 04:32 PM
acura9's Avatar
Default Re: (phayzeone)
haha i think ill stick with my motor is out of an 01 integra with about 60k on it now everything runs great no problems so im sure once i start in building process i shouldn't run into any problems like that
