project integra
i have a 1991 integra ls i plan to buy the bolt ons tommorw and eventually swap it over to ls/vtec should be done sometime soon also plan on buying hondata in opinion what else should i do engine wise besides nitrious. here is a pic now...
i plan on lowering with new coil overs and springs once i get more money up
inside
inside
haha i accidently put in the wrong thing i don't want to put nitrious in there but ya then just boost it then basiclly??? and if so what kind should i go for i don't want any ebay kits
do u think i can do wheelies when this is all done haha jk but how much hp u think ill be making just with boost and try and get mostly everything else inside the enigine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acura9 »</TD></TR><TR><TD CLASS="quote">how much hp u think ill be making just with boost and try and get mostly everything else inside the enigine?</TD></TR></TABLE>
After all the research you do, and then eventually get it all done,
The dyno you test the car out on will tell you exactly how much it will make.
But just a Rough number, low-moderate boost on a nicely sized compressor,
and you should make anywhere from 150-250hp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acura9 »</TD></TR><TR><TD CLASS="quote">i have a 1991 integra ls i plan to buy the bolt ons tommorw and eventually swap it over to ls/vtec should be done sometime soon also plan on buying hondata in opinion what else should i do engine wise besides nitrious. here is a pic now...
inside</TD></TR></TABLE>
YA!!!!!!!
lol i have that hat!!!!
so bump haha
YA!!!!!!!
so bump haha
i plan on lowering with new coil overs and springs once i get more money up</TD></TR></TABLE>
Coilovers and springs....one or the other
to do it right you will have to do a new pump,fpr and injectors with a tune. Might as well just boost it. Been there done that u will be a lot happier with boost!
First spend your money on getting the car running pefectly. Make sure all the maintenance is up to date. Check all wear items; i.e. bushings, balljoints, tie rods, hoses, etc. Your just going to run into tons of problems in the future if you avoid all this.
Ali
Ali
inside</TD></TR></TABLE> to start what head b16 or b18c1? what bolt on's?and are u gonna run stock internals on nitrous? also which one coilovers or springs cant have both.....?
haha i think ill stick with my motor is out of an 01 integra with about 60k on it now everything runs great no problems so im sure once i start in building process i shouldn't run into any problems like that
